Old 03-17-2011, 08:39 AM   #736
gsxr0311's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Blueman Austria View Post
Chek this out! (Last post)
http://www.rctech.net/forum/electric...f415-1396.html
Greetz Blueman
NICE, thanks perfect timing. did you use the 416 spec-r diff? also would you happen to have the part numbers of the parts you used to convert it?
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 03-20-2011, 03:11 PM   #737
Barry_Hughes's Avatar
Built my spec R for the TCX
It feels nice and smooth with 1000K oil, but one of the outdrives has about 1.5mm play by which I mean I can pull the outdrive outwards by this amount, th other side has very little movement.
Should I take it apart and add shims so there is no movement at all?
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 03-20-2011, 07:56 PM   #738
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
yes...add 0.5mm shim will be ok.
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-22-2011, 08:40 PM   #739
vadersing's Avatar
Originally Posted by warnos View Post
Re the cyclone.. it fits but u need to shim it..
Could someone share how to use the TCX gear diff for Cyclone TC?
vadersing is offline   Reply With Quote
Old 03-23-2011, 06:14 AM   #740
bigz's Avatar
is it advisable to put sealant around the diff housing? my diff always leak. am using the green gasket.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 03-23-2011, 08:31 AM   #741
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I've done that and it works fine. You have to use an exacto knife to reopen the diff but that's not a real problem. I read somewhere on here the some are using the large o-ring from the Xray NT1 diff ring to help seal the diff. I want to give that a try...you may want to look into it too.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 03-23-2011, 09:31 PM   #742
Coldn's Avatar
Send a message via MSN to Coldn
hello guys, whats happens if I put the different density of oil in the gear diff.
with a hard oil, my car will be more fast? whats the perfect density of oil?
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 03-23-2011, 10:47 PM   #743
gonzo416's Avatar
Trader Rating: 39 (98%+)
Can't find one for xray 38t.
gonzo416 is offline   Reply With Quote
Old 03-24-2011, 07:50 AM   #744
SlideMasteR's Avatar
Questions??
any news on the gear diffs for the schumacher's ?
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 03-24-2011, 07:52 AM   #745
getpip's Avatar
+1
LOL .. I came to ask the exact same question.
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 03-24-2011, 10:19 AM   #746
bigz's Avatar
Originally Posted by PitNamedGordie View Post
I've done that and it works fine. You have to use an exacto knife to reopen the diff but that's not that real problem. I read somewhere on here the some are using the large o-ring from the Xray NT1 diff ring to help seal the diff. I want to give that a try...you may want to look into it too.
thanks.
Old 03-24-2011, 10:54 AM   #747
Chubba's Avatar
I use the large o ring from xray and works great. So far so good no leaks!
[Mugen MRX 5] [Yokomo R12] [Xray T3 2011] [Xray X10 Link] [KM HK-1]
Chubba is offline   Reply With Quote
Old 03-24-2011, 11:10 AM   #748
J.Gonzalez's Avatar
It is not a direct fit by an means. I got it to work.
I used flanged bearing in diff eccentric instead of standard bearing.. and I ground the inside of the alum. ring that fit on diff to work as a spacer on the gear diff...reversed the left and right bulkheads on the chassis so the ecentric doesnt sit into the bulkhead...grind down/reprofile the plastic blades on dogbones so the suspension moves in full stroke.
If you want I can send pics just pm me.
I bought them as some nit wit said they fit on the forum...trust me they dont fit. You can make them fit with lots of fiddling. The tcx bulkheads are much narrow than cyclone bulkheads.
They work great if that is any consolation!
Jamie
J.Gonzalez is offline   Reply With Quote
Old 03-24-2011, 02:11 PM   #749
Originally Posted by getpip View Post
+1
They are listed on Schumacher's website, but they are out of stock. Check my post in the Mi4 thread.
I was on the phone with a sales lady at Schumacher last night to sort out a declined payment, and asked about the diffs. She said she's pretty sure they have them on order, and the website should be updated when they come in stock. I'm gonna keep close tabs on it.
-Mike
Old 03-24-2011, 08:10 PM   #750
gonzo416's Avatar
Where can I get one or two for XRAY 38T?(T3 & T2 08)
