Old 03-13-2011, 07:07 PM   #721
warnos's Avatar
Hi they are the new gaskets and Xring's for the shafts.. it only leaks at the pulley.. cross tightened and also sanded.. followed the instructions on the youtube vid from spec r.. bigger shims 0.2 used..
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 03-13-2011, 08:09 PM   #722
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Sounds like your just over filling it you only need to fill it up to just below the plastic T
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 03-14-2011, 03:43 AM   #723
Like JasonC says - if everything else is okay, you are probably using to much oil.
But it is normal for it to leak a little for the first couple of runs.
Regarding the shims, I can't say if it better, as I have only used the standard shims provided with the geardiff, and my diffs work great.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 03-14-2011, 07:23 AM   #724
bigz's Avatar
also have that problem, mine is for a tcx with the green gasket. sanded the gears and tightened it in x pattern but still leaking in the pulley. not overfilling it either since everything is ok the first 3 laps then kaboom, no oil. all is spilled in the chassis. any help guys? will i need to get a new set? please wait 2 seconds for an uncompressed image, or press Ctrl+F5 for original quality pageplease wait 2 seconds for an uncompressed image, or press Ctrl+F5 for original quality page
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 03-16-2011, 12:56 PM   #725
gsxr0311's Avatar
Trader Rating: 19 (100%+)
hay guys and gals, do you know if any spec r diffs fit my tamiya 415?
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 03-16-2011, 06:38 PM   #726
Chubba's Avatar
Hi there I have just bought the spec r diff for my X-ray T3. I was wondering what is the difference between the stock diff gaskets that come with the set and the green version 2 diff gaskets? What does it mean that they are matched with 0.2 mm internal shim?
[Mugen MRX 5] [Yokomo R12] [Xray T3 2011] [Xray X10 Link] [KM HK-1]
Chubba is offline   Reply With Quote
Old 03-17-2011, 12:40 AM   #727
Blueman Austria's Avatar
Chek this out! (Last post)
http://www.rctech.net/forum/electric...f415-1396.html
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 03-17-2011, 12:45 AM   #728
Default Sanding the gears ?
I have e question about (how much) sanding the gears from the Spec R diffs?
I build one for the 416, and one for the TB03, and only had a used 1000 sanding paper for polishing/sanding the gears.
I builded them up per instructions, and think that the gear mesh is to thigt.
With wich kind of sanding paper, or other stuff did you guys sanded/polished the gears, and how much?
BTW. i filled both with 1000 oil.
Greetings Blueman
Old 03-17-2011, 02:44 AM   #729
I use 600 sanding paper.
The gears do need quite a lot of sanding to get the geardiff silky smooth. If you can feel the gears / the teeth when the geardiff is assembled and you turn it by hand, then it needs more sanding.
Niklas Hansen
Old 03-17-2011, 02:59 AM   #730
Chubba's Avatar
I will build my new spec r diff tomorrow for my T3. what do you mean by feeling the gears / the teeth?
Old 03-17-2011, 03:16 AM   #731
It is hard to explain (especially when english is not my first language), but when you turn the outdrives, it has to feel silky smooth. If you can feel the gear-teeth touching when you turn the outdrives, then it needs more sanding. It can take a couple of tries.
Niklas Hansen
Old 03-17-2011, 03:28 AM   #732
Chubba's Avatar
Thanks for your explanation. You only sand the rear of the gears right. and also what is the shims adjustment for?
Old 03-17-2011, 03:53 AM   #733
Yes - Only the back of the gears. If you don't sand the back enough, they will sit too close and be too tight.
I can't answer you on the shims question. I just use the stock shims and my diffs work great.
Niklas Hansen
Old 03-17-2011, 06:00 AM   #734
Do you only sand the back of the outdrive gears or also the smaler "cross" geasrs? or both the same way?
Thx for the info!
Old 03-17-2011, 06:31 AM   #735
Thx for the info!
I sand all the gears.
Niklas Hansen
