Old 11-28-2010, 09:24 AM   #646
georgec's Avatar
Originally Posted by RevMaxx View Post
u can build a gear diff for cyclone TC using the NT1 gear diff.
use the front pulley of the TC ang patch it to the NT1 gear diff case. get the correct alignment and u should be fine...
All the NT1 diffs that I saw modified to fit other cars looked like they were done using a sledge hammer and chainsaw until I saw this one! I think I know how it was done and have access to a lathe so I'm going to give it a shot!
georgec is offline   Reply With Quote
Old 12-11-2010, 09:51 PM   #647
2-Bad's Avatar
Trader Rating: 24 (100%+)
Anyone know which online shop has the Gear diff for the Tamiya 416/417 in stock (damn hard to find)? Preferably out of Hkong, but elsewhere too...
thanks....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 12-12-2010, 03:40 AM   #648
you could try at http://www.kshobby.com
They have great service and the geardiffs are quite cheap.
addicted2blue is offline   Reply With Quote
Old 12-12-2010, 03:42 AM   #649
or Ebay ??
sidecarphil1 is offline   Reply With Quote
Old 12-12-2010, 04:38 AM   #650
OverGeared's Avatar
Got the Spec-R gear diff on the rear of my TRF416WE filled with Kyosho 1000cst silicone diff oil. I'm running on a medium sized, high bite outdoor track. Car's rear end tends to have a slight slip coming out of the hairpins so I changed the oil to Mugen 2000cst silicone diff oil. Car's handling is now perfect and much more planted on the chicanes. Had the issues of leaking initially (as can be seen on the chassis and body) but after 2 heats t'was ok, no leaks on the outdrives.
OverGeared is offline   Reply With Quote
Old 12-12-2010, 05:40 AM   #651
2-Bad's Avatar
Cheap they are, but only for Yok & Xray
Strange how on KS Website say they are from HK, and yet there contact number is in Malaysia...
and no ebay listing.... :-(
Old 12-12-2010, 05:51 AM   #652
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
yeah, as i'm doing the shop with my partner there.
tamiya geardiff will restock soon...
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-07-2011, 04:49 AM   #653
georgec's Avatar
Just thought I would post back in on how well the Spec-R gear diff has been holding up. Have been running the diff in a T3 with a 17.5 D3 no boost with no major problems, only a tiny bit of leaking. Works so well and so cheap to maintain I don't believe I will ever use a ball diff again! Rebuild kit for the gear diff is less than seven bucks, thrust bearing alone on the T3 ball diff $21.00
Old 02-07-2011, 07:06 AM   #654
Bytor's Avatar
Thanks for the update. I purchased mine recently and put it together Saturday as I am switching everything over to my Exotek chassis. I cannot want to give it a shot soon.
Xray T2 '009 EU|Exotek|Tekin|Trouble
AE TC4|RCGT|Bring It!
Slash 4x4|Stock|Give me some dirt!
Radio Control Racers of Northern Virginia - http://www.rcrnv.com/ - 2011 VA Points Series
Bytor is offline   Reply With Quote
Old 02-07-2011, 08:35 AM   #655
kschu's Avatar
try with 1000 oil ....
Old 02-07-2011, 09:34 AM   #656
gonzo416's Avatar
Trader Rating: 39 (98%+)
Does anyone know if the SpecR gear diff fits the XRAY T2 08?
gonzo416 is offline   Reply With Quote
Old 02-07-2011, 10:22 AM   #657
You can either convert the car to 38T pulleys and use the T3 geardiff, or you could try to get a Spec-R 34T geardiff. I bought 2 Spec-R 34T geardiffs from Demon Power Products, and they are working great in my T2 '009.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-07-2011, 11:17 AM   #658
gonzo416's Avatar
I know it can be converted to 34/20, Do you know what belts I need to convert to 34/20?
Can it be converted to 38/20? If so, what belts.
Old 02-07-2011, 12:36 PM   #659
bencason's Avatar
Does anyone know if there is a SpecR gear diff that fits the XRAY T2 07?
There is a diff for "T2/T3" but it doesn't specify which T2 models it works with.
The RC cars are in storage but not forgotten
One of these days, I'll be back to racing... somewhere
bencason is offline   Reply With Quote
Old 02-07-2011, 01:40 PM   #660
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
38T conversion kit parts list:
http://www.teamxray.com/teamxray/pro...Name=T2\%B4009
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
