Old 11-20-2010, 10:28 AM   #631
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Nevermind, answered
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 11-22-2010, 04:29 PM   #632
syndr0me's Avatar
Trader Rating: 32 (100%+)
What do you guys do when the washers deform and make the diff bind up? Replace them, or just take them out entirely?
syndr0me is offline   Reply With Quote
Old 11-22-2010, 04:36 PM   #633
i pull everything out, throw it away and put new everything in
XRAY T3 | Team HEI Australia
gameover is offline   Reply With Quote
Old 11-23-2010, 01:32 AM   #634
I had this happen to my 416x over this last weekend and I was wondering whether slightly thicker shims might do the trick. Anyone got any ideas. I had no issues with leakage due to not overfilling the diff. Other than that I loved the geardiff.
Bumpy is offline   Reply With Quote
Old 11-23-2010, 02:52 AM   #635
jonest's Avatar
I'm using thicker shims....
jonest is offline   Reply With Quote
Old 11-23-2010, 08:14 PM   #636
I always use 0.1mm shim then follow by stock o-ring in both halves.
Never have any problem about collapse shim and it turns super free, my diff still leak a little though.
If you carefully assemble the diff, you will notice that the o-ring sits too deep in its place, that might be the cause for collapse shim.
b20b is offline   Reply With Quote
Old 11-23-2010, 09:43 PM   #637
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Dunno how you guys are getting the leaking issues. I built mine fairly straight forward.
Used all the stock parts. Coated the X-Rings with Associated green slime. Didn't overfill the diff. 1000K Kyosho oil. Standard gasket with a small amount of RTV gasket sealer...
Four race days on this diff now. Something like 9 6min quals, 4 6min mains, probably 5-7 6+min practice runs. By gas car standards this diff should be rebuilt but it feels perfect and no leaking.
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 11-23-2010, 10:37 PM   #638
syndr0me's Avatar
I had the pin slot on one of the crown gears chip away after a wreck tonight and cause the diff to start slipping under power. I was running it without the shims. I replaced all the internals after that and everything was happy again.
I built my diff with the new seals (green slimed) and 2k oil, not overfilled, and it leaks all over the damn place.
Old 11-24-2010, 12:06 AM   #639
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Hi guys since there is talk about leaking between the two half and the seals i had a mate make me some out of double thickness and softer gasket paper so i could put .2 shims in behind the crown gear and to stop the leaking between the two half,s and had no problem since and for the o-rings i changed them from the new x-ring to a o-ring i get from work and no problem there to. Spec-R Gear diff review-img_0195.jpg
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 11-24-2010, 09:41 PM   #640
georgec's Avatar
I thought I would post up the results of my second go with the Spec-R gear diff. My first run with the diff I tried Mugen 1000wt diff lube with very poor results, this time I upped the diff lube to 3000wt with very positive results! After running four packs I was back up to my normal lap times. The rear of the car felt planted this time, so..so far so good. Now I just need to see how well it holds up compared to my Xray ball diff. Time will tell!
georgec is offline   Reply With Quote
Old 11-24-2010, 10:45 PM   #641
Same problem here.
I have the new x orings in, with an additional 0.1 shim on each side.
Diff not over filled with 2K oil.
Damn thing leaks by the outdrives, I read that there are new shims/spacers out for the gear diff.
Anyone where we can buy them from?
I also recently changed over to a 3R gear diff, waaay better/more robust imo and no leaking at all.
SeanV is offline   Reply With Quote
Old 11-24-2010, 11:24 PM   #642
jake95's Avatar
Trader Rating: 27 (100%+)
my gear diff is great how often should you change the seals and gasket
thanks
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 11-25-2010, 06:06 AM   #643
georgec's Avatar
thanks
Not to be a smart a$$, but when it starts to leak
Old 11-25-2010, 08:30 AM   #644
hi, iam not sure about what i read so i ask again. What Differential i need to buy and what modification i need to do to put a gear diff on the rear of my Cyclone TC ( not TCX). ty
CoCoLapin is offline   Reply With Quote
Old 11-25-2010, 08:56 AM   #645
RevMaxx's Avatar
Send a message via MSN to RevMaxx
u can build a gear diff for cyclone TC using the NT1 gear diff.
use the front pulley of the TC ang patch it to the NT1 gear diff case. get the correct alignment and u should be fine...
RevMaxx is offline   Reply With Quote
