Old 11-17-2010, 06:57 PM   #616
AE-Reedy
Originally Posted by corallyman View Post
Sean,
US or overseas? I saw an overseas shop with one left. Interested?
Steve
Thanks for the replies guys, I got a lead on a shop that had both SpecR and Yokomo. Just waiting for confirmation that they for sure had them in stock.
Sean Cochran is offline   Reply With Quote
Old 11-17-2010, 07:12 PM   #617
guinnes.s's Avatar
just got one spec r for my trf416 ,followed the building instructions but it does not feel smooth at all,i can feel the gear teeth under my fingers when rotating the out-drives.
am i missing something???hope someone can help.
thanx
guinnes.s is offline   Reply With Quote
Old 11-17-2010, 07:20 PM   #618
hanulec's Avatar
Trader Rating: 27 (100%+)
the spec-r gear diff feels rough until you run it. it will smooth out after the first one or two runs.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-17-2010, 09:26 PM   #619
thanx
in 1/8th offroad, we shim the planetary gears and put it together until it feels right. The gasket's thickness plays a part too
cheapskate.brok is offline   Reply With Quote
Old 11-17-2010, 11:33 PM   #620
ferrarieeeee's Avatar
thanx
For me I need to polish the back side of the gears to reduce the thickness (as told in the instruction sheet) and not to tighten the screws too much.....
Electric: eb48.3 / eb48sl / 811e / d413 / b5 / b5m / kr / pro2b / msc / scte
Nitro: nb48.3 / xb8
ferrarieeeee is offline   Reply With Quote
Old 11-18-2010, 01:47 AM   #621
I am getting a gear-diff for my Xray T2 '009 (on carpet) (SPR009-XR). Is the so-called X Ring included with the newer gear-diffs?
The site also says: "*** For XRay T3, 50mm rear universal swing shaft should be required. ". But what about T2 '009? Do I need 50mm driveshafts for that also?
And what should I start out with? 1000cst?
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 11-18-2010, 02:27 AM   #622
yes, u will need the shorter 50mm shafts, otherwise it will bind with the diff cup. Start with 2000 oil.
hardmankam is offline   Reply With Quote
Old 11-18-2010, 04:32 AM   #623
georgec's Avatar
Originally Posted by hanulec View Post
No one said it would be easier to drive. If you were spinning out then u where probably digging out so going to a thicker oil is smart. I run 3000cst mugen oil in mine on carpet.
The gear diff on asphalt is much easier to get used to. I think we are all looking for the magic setup on carpet...
Yea, I think we would all like that magic setup for rubber tires on carpet =-)
I do tend to throw the car into the turns, break late and hard but that's what works for me. I'll hold onto it till next summer and give it a go on the black top.
georgec is offline   Reply With Quote
Old 11-18-2010, 05:51 AM   #624
hanulec's Avatar
Why don't u try slow in and fast out. It will be quicker regardless of ball or gear diff.
Old 11-18-2010, 06:08 AM   #625
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
true that.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 11-19-2010, 02:46 PM   #626
do any of the diffs fit the xray t2r pro?
Austin Strykul is offline   Reply With Quote
Old 11-20-2010, 06:29 AM   #627
hanulec's Avatar
How many teeth is in your T2R diff? 34t or 38t? There are diffs that fit both. The 34t diff says its for the Atomic vm2 but it is exactly what an xray with 34t needs. I have an xray ball diff out of a T2'008 in my vm2
Old 11-20-2010, 06:43 AM   #628
I should have known that, before I went out and bought a 38T conversion kit for my T2 '009
Niklas Hansen
Old 11-20-2010, 07:07 AM   #629
hanulec's Avatar
Sorry dude...
If you searched the thread u would of seen me post that info before ..
Old 11-20-2010, 09:45 AM   #630
Sorry dude...
Yeah, my own fault. Didn't do some research beforehand.
Niklas Hansen
