Old 09-19-2010, 09:03 PM   #556
san.'s Avatar
Trader Rating: 60 (100%+)
Originally Posted by Mike Haynes View Post
Does anyone know which spec r gear diff will fit in the tcx? I would think the tamiya one? Thanks
edited: found the answer:
http://www.rctech.net/forum/7741200-post377.html
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 09-20-2010, 01:51 AM   #557
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
anyone try running a gear diff front and rear?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 09-20-2010, 02:28 AM   #558
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Yokomo_Ant3 View Post
Does anyone know were to get oil in finer increments (around 20k) of oils ranging from 150,000 to 500,000? Or am i going to have to mix my own?
Thanks,
Antoni
Anyone?
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 09-20-2010, 06:05 AM   #559
Satish's Avatar
Originally Posted by joey View Post
if your looking for the xray version, Nexusracing has them in stock..
http://www.nexusracing.com/product_i...oducts_id=3267
Actually i am looking for one to put in a 416X
my bad )
Satish is offline   Reply With Quote
Old 09-20-2010, 06:38 AM   #560
Trader Rating: 68 (100%+)
Send a message via AIM to joey
my bad )
http://store.hkshobby.com/product_in...oducts_id=7204
=Joe Wright=
joey is offline   Reply With Quote
Old 09-20-2010, 07:31 AM   #561
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
i have been running gear diff front and rear for the last 2 months and it works very well , using 120,000 diff oil in the front and 10,000 in the rear
Old 09-20-2010, 07:50 AM   #562
Satish's Avatar
Is there a place in the US that sells this?
s
Old 09-20-2010, 08:04 AM   #563
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
s
HKS is in California.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-20-2010, 08:16 AM   #564
M-Technic's Avatar
Trader Rating: 15 (100%+)
I ran my Spec R gear diff in mod for the first time this weekend. The diff held up fine but it was hard on the drive train with a spool in the front. I stripped a couple of belts and then went so far as stripping one of my center pulleys in the main.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-20-2010, 08:38 AM   #565
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Spec-r geardiff available here...
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-20-2010, 07:23 PM   #566
Bullz's Avatar
Originally Posted by itchynads View Post
Changing to the new X O-ring makes no differences from what I can tell. It still leaks. The leaking from the pulleys can be fixed with some automotive sealant. They really should release some rubber gaskets for the diff.
Hi Itchynads, i used the "X-ring" now and no leak so far. Last build was 1 month ago with 130,000 oil. Got it from Kshobby website. I play 7 days a week with at least 4 LIPO pack, running MOD with LRP 4 Turn brushless. with weather condition 32-34c degree. I agreed with you that it will be nice, if they were to release a rubber gasket.
Bullz is offline   Reply With Quote
Old 09-20-2010, 09:23 PM   #567
You are running thicker oil so I'm not suprised it does not leak .
I'm running 1000cst in the rear which is more runny.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 09-27-2010, 02:07 PM   #568
Still looking for shims suitable for the spec-r diff please, preferably in the UK.
Zen RSGT, Trinity, Hobbywing, LRP.
M05 S-Spec, LRP, Intellect.
M05 v2 Tekin, Orion, Savox.
B44 Mamba Max, Trakpower.
B44.2 Avid chassis, Speed Passion, Gens Ace.
BILKO1 is offline   Reply With Quote
Old 09-27-2010, 04:09 PM   #569
i'd like to know too. these shims are the weak link of this diff, they mushroom very badly over time in 10.5t and mod
XRAY T3 | Team HEI Australia
gameover is offline   Reply With Quote
Old 09-28-2010, 03:11 AM   #570
jonest's Avatar
I've changed to a slightly bigger (outer diameter) shims, if not wrong 4 x 10 x 0.2mm..... check out Hong Nor's buggy shims.
jonest is offline   Reply With Quote
