Old 08-23-2010, 06:16 AM   #481
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Anyone tested the new o-rings? Any better
Cheers,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 08-23-2010, 06:42 AM   #482
TheCoolCanFanMan's Avatar
Originally Posted by tellan View Post
Malc
hope things are going good for you after your news. But all this hassle with TCs .Go out and buy a 1/12th car.
You get more track time 8 mins instead of 5 and save your self a bundle of dosh.
And mess around with truing tyres, I don't think so lol
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 08-23-2010, 09:11 AM   #483
jag88's Avatar
Cheers,
Antoni
I've put a few runs on them and there was still a leak. This was with 1000 cst. in the rear.
I've gone back to a spool and diff. just to get a comparison.
jag88 is offline   Reply With Quote
Old 08-23-2010, 10:42 AM   #484
JayL's Avatar
my initial slop, after two race days, has stayed at that point and has not increased after 4 more race days in mod
Not sure what kind of a business model makes parts for discontinued products.......
JayL is offline   Reply With Quote
Old 08-23-2010, 11:16 AM   #485
Originally Posted by Hurrle View Post
Does the Sakura diff fit Xray T3?
I want to know the same, the price of the 3racing gear diff is lower than any other.
On 3racing blog says:
Gear Differential 37T and 38T are workable with 3.5 T to 4.5T modified motors, it fits all car models if some right adjustments of the chassis are made.
Can anyone confirm this?
ARC R11 - LRP Powered
Find RC news on: http://www.rcelectrico.es
Psycho_ is offline   Reply With Quote
Old 08-23-2010, 11:32 AM   #486
I put my diff together on Frinday night, raced a full day Sunday and had zero issues! The diff makes a nice difference on the track. Corner speed was up and kept very consistent through the day.
I built the diff as per instrcutions with Associated 1000 oil. VERY little leak at first, but it stopped.
Over all I'm happy and glad I bought one.
Turillo is offline   Reply With Quote
Old 08-23-2010, 04:59 PM   #487
auzzy_mate's Avatar
Default Spec-R Gear Diff Testing
Morning All,
A Ball Diff can be tested by holding a wheel (and/or the spur) to feel how "tight/loose/smooth" it is, but can anybody tell me a way of testing the Spec-R Gear Diff without actually running it?
Ben
auzzy_mate is offline   Reply With Quote
Old 08-23-2010, 05:16 PM   #488
Skiddins's Avatar
Originally Posted by auzzy_mate View Post
Morning All,
Ben
What are you trying to test?
If you hold the spur and one wheel, if you try turning the other wheel it should move only the small amount to take up the slack though.
It should feel pretty smooth if you hold the spur and just turn one of the wheels.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-23-2010, 05:17 PM   #489
auzzy_mate's Avatar
Default Spec-R Gear Diff build
Morning All,
I built and fitted a new Spec-R Gear Diff last night and took a few photos along the way. I thought I would post them here just to let new/interested users have a look at what a build is like.
Feel free to add comments/tips .
Ben
Spec-R Gear diff review-10.jpg   Spec-R Gear diff review-11.jpg   Spec-R Gear diff review-12.jpg   Spec-R Gear diff review-13.jpg   Spec-R Gear diff review-14.jpg
Old 08-24-2010, 07:02 AM   #490
Skiddins's Avatar
Morning All,
Ben
I would add that using some thick grease, like Schumachers around the inside of the hole for the outdrive, then pushing the outdrive through the grease etc into position helps creates a better oil seal.
I also greased the O-ring before putting that into position.
Pictures are good, but too small.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-24-2010, 08:46 AM   #491
bodymot's Avatar
Default FG sticky grease
Right, donít shoot me down and probably wouldnít be right for a top racer,
But for a club racer have you tried FG sticky grease FG06512.
I now use it in Tamiya mini gear diff but also use it in spec-r diff fitted in X-ray T3.
It helps stop the wheel spin out so much when it lifts in corners,
gives less free play in the diff and dose not leak out. Also because the gears do not spin so much makes it last longer.
Iím not a top Touring car racer but not had to rebuild the r-spec diff since Iíve had it.
Might not be the right way for top racers but for a club racers works great.
I got a spec-r diff because wanted something which stayed smooth and could put in car and forget,
unlike ball diff which after a few races needed a rebuild.
TC .UK. Tamiya M05, X-ray T3-09, GM Genius 120, MAMBA MAX PRO.
Member of T.M.F.F.R
bodymot is offline   Reply With Quote
Old 08-24-2010, 09:45 AM   #492
dameetz's Avatar
Guys, I build and tested the 3Racing gear diff today. Package wise 3Racing is better, it includes everything you need for operation (37t and 38t pulleys, bigger internal shims for the outdrives, metal cross shafts, 3.5mm drive shafts blades, Silicone Oil: I don't know the viscosity coz there is no label or info on the bottle, RUBBER GASKET which is good compare to the paper one from Spec R, 2x diff bearings and some various thickness bearing spacers to make the diff fit to some car models)
During building I felt that the casing around the outdrives are a bit tight, so I put some grease on the out drive shafts and this helps smooths it out a bit. After a few runs testing it today the diff is smooth like butter. And the best part for me over the Spec R is there is NO LEAK at all. Overall I m very happy.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 08-24-2010, 10:44 AM   #493
jonest's Avatar
After running the spec r gear diff for a few races and experience failure too, building the 3racing gear diff brings my confidence back... The overall quality of the item are at least double the spec r standard, well at least the shims are double the size while it's not only one piece, but two pcs required on both ends while the rubber gasket is recyclable and most importantly it's cheaper by a third of spec r!
I just can't wait to try it on the track. Any1 has done it and how's the reliability of the 3racing gear diff?
P/s: I'm running a TRF 416 FX (Smokem chassis) and I believe it should fit the X Ray T3 chassis as well.... Cheerios
jonest is offline   Reply With Quote
Old 08-25-2010, 05:07 AM   #494
I for one am not really impressed by it. On high grip carpet tracks it was pretty good, but when the track is low grip the car want to keep on turning slightly, particularly on power. Its just a pain in the
I've tried 150cst to 2000cst and I have yet to see anything over a really well set xray ball diff with associated grease. It seems the ball diff has a bit more slack when you put the power down. Almost like it has a small amount of slip even when there isn't. I was immediately quicker when I put the ball diff back last week on a low grip carpet layout.
Dont get me wrong, it works ok, but I find theres more downsides to the Spec-r diff than originally thought. When using thin oil the thing leaks a lot and when I thicken the oil it has poor performance so I cannot win with it. Tried more gaskets etc, differnt o-rings, still no joy. I can see it working outdoors, but indoors its not doing the job I want it to do. As for maintenance free........................
maxg123456 is offline   Reply With Quote
Old 08-25-2010, 06:29 AM   #495
ark
would be good if the gear diff had an adjustable slipper to it
ark is offline   Reply With Quote
