Old 08-17-2010, 06:07 AM   #466
RC MARKET's Avatar
Tested 3 Racing Sakura Gear Diff. fit in TRF416 to use ,
price is lower & with bearing , silicone & Shim set !!
http://rcmarket.com.hk/product_info....her7s3b02jtit4
RC MARKET is offline   Reply With Quote
Old 08-17-2010, 06:38 AM   #467
veecee's Avatar
Trader Rating: 34 (100%+)
3Racing site says this diff needs 3.5mm blades? Tamiya blades are 3mm...
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 08-17-2010, 07:32 AM   #468
RC MARKET's Avatar
included 3.5mm baldes , later have spare for sale !
Old 08-19-2010, 12:32 PM   #469
Does the Sakura diff fit Xray T3?
Hurrle is offline   Reply With Quote
Old 08-19-2010, 12:40 PM   #470
I couldnt wait to try mine and put some 55wt corally shock oil in it , it made the rear really loose on power
Is this due to the oil or is this one of the traits of the gear diff ???
sidecarphil1 is offline   Reply With Quote
Old 08-19-2010, 12:52 PM   #471
mr fit's Avatar
would a spec-r gear diff work in a mi-4. if so which one?
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 08-19-2010, 06:43 PM   #472
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
the oil is too thin....try 1000 or 3000 to calm down the rear...
Give the best while u can !
kschu is offline   Reply With Quote
Old 08-19-2010, 10:44 PM   #473
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
you want 100 wt shock oil minimum. 1000-3000 cst as ks mentioned
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 08-19-2010, 11:39 PM   #474
CraigM's Avatar
Mine should arrive today or monday, will try it back to back with the spec r next weekend. Have been very happy with the performance of the spec r but after only a few meets there is a lot of slop between the outdrive pins and the gears. Hopefully the 3r is just as good on the track but lasts longer
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-20-2010, 02:37 AM   #475
kschu's Avatar
you must sand behind the gear to have clearance 0.1 - 0.2mm to reduce the pressure to the pin. this will make it last longer...
Old 08-22-2010, 11:56 PM   #476
auzzy_mate's Avatar
Default Gasket
Can anybody tell me what the gasket is made of?
Thickness?
Ben
auzzy_mate is offline   Reply With Quote
Old 08-23-2010, 12:44 AM   #477
adrian_pg's Avatar
Send a message via AIM to adrian_pg
Thickness?
Ben
Looks like G10/G20, Industrial Insulator Material. Goes the same with the gears...
''Gosh... My wife going to divorce me, if I kept spending time in RC"...
///MEMBER OF PPRCC///
adrian_pg is offline   Reply With Quote
Old 08-23-2010, 01:01 AM   #478
RC MARKET's Avatar
Ok Thanks !
Old 08-23-2010, 02:50 AM   #479
TheCoolCanFanMan's Avatar
Hi Spec-R and anyone else that can answer this question
Well I managed to borrow a Spec-R diff from a buddy yesterday that has a Tamiya 416, to find out if it would fit my HB TC, it dropped striaght in, but the down side is, HB use a 39 tooth pulley, is there a 39 tooth pulley Spec-R make, as I could use Tamiya drive shafts in the rear to accomadate for the slots in the outdrives, but why o why cant Spec-R not make one for the HB cars, it surley cant be that difficult to make the outdrives accomodate the drive-shafts for the HB cars along with a 39 tooth pulley. In fact if you could supply a 39 tooth pulley, I could get the outdrives machined to accomodate the HB Litemodz CVS's
Spec-R please reply to this question.
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 08-23-2010, 03:01 AM   #480
Default drive shafts
Malc
hope things are going good for you after your news. But all this hassle with TCs .Go out and buy a 1/12th car.
You get more track time 8 mins instead of 5 and save your self a bundle of dosh.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
