Old 08-04-2010, 07:25 AM   #406
Originally Posted by Skiddins View Post
http://demonpowerproducts.co.uk/adva...cturers_id=163
Are you sure you built it correctly?
Thanks Damian, i'm sure i built it correctly i spent ages getting the gears super flat and polished. To be honest i was a bit miffed when i stripped it down and saw the wear after such short use. I've found some suitable pins just need some shims now.
Zen RSGT, Trinity, Hobbywing, LRP.
M05 S-Spec, LRP, Intellect.
M05 v2 Tekin, Orion, Savox.
B44 Mamba Max, Trakpower.
B44.2 Avid chassis, Speed Passion, Gens Ace.
BILKO1 is offline   Reply With Quote
Old 08-04-2010, 08:00 AM   #407
yokemad's Avatar
I think you can use xray model with 52mm CVds if you put it on 008/009 because they are different from T3...
T3 has build in 1 degree toe-in but 008/009 hasn't got that hence you use more shims to hit 3degrees =wider rear end ...
There is a big gap with 50mm driveshafts ,I'm gonna try 52mm on 008 to see if it's gonna be ok
Has anyone tried that before?
yokemad is offline   Reply With Quote
Old 08-04-2010, 01:11 PM   #408
RC MARKET's Avatar
Originally Posted by BILKO1 View Post
Ran my spec-r diff for 5 heats and a final and it didn't feel smooth after. Stripped it down and the shims have worn really bad and the 2 pins are worn to. Does anyone know where i can get new shims and pins in the UK? Apart from the wear the diff ran great and did not leak i was using a 13.5T.
HK same had many these case !
RC MARKET is offline   Reply With Quote
Old 08-04-2010, 02:52 PM   #409
JayL's Avatar
RC MARKET: Any chance you have tried other gear diff internals in the spec-r case, seeing as how you have access to them all ?
I'm thinking this would be the best setup, get rid of the cheap plastic inside and not have to "hack up" a case like the xray NT1
JayL is offline   Reply With Quote
Old 08-04-2010, 03:08 PM   #410
RC MARKET's Avatar
We used XRAY NT1 Rear gear diff with Xceed Nylon gear & LW shaft ,
not have issues !
or wait moment 3 Racing will delay to this month release his gear diff !
Old 08-04-2010, 05:20 PM   #411
yokemad's Avatar
Tried that and wont fit so 5o mm shafts must have
Old 08-04-2010, 05:24 PM   #412
+1
Old 08-04-2010, 11:19 PM   #413
DriftDreamer06's Avatar
Originally Posted by CouldbeFaster View Post
Hi Moontrap...
A guy im racing with has a TC5, with a photon gear diff.... Its basically fits... Stick a few shims on it... Job done.....
are you positive on this? as i am looking to run two cars - one rear gear diff the other front and rear gear diffs. if you could snap a picture that would be really cool.
are there any other of manufactors out there making gear diffs - of course for a TC5???
DriftDreamer06 is offline   Reply With Quote
Old 08-05-2010, 01:08 AM   #414
it does fit, but needs shimming
CPD Racing
chris_dono is offline   Reply With Quote
Old 08-05-2010, 12:31 PM   #415
yokemad's Avatar
My one also Leaks both Around the Pulley and near shafts...
there should be big O ring around the pulley to seal it and maybe better o rings around shafts...
Old 08-05-2010, 12:38 PM   #416
jag88's Avatar
According to Mr. Tanaka from Spec-R there's a new o ring coming ....... soon.
jag88 is offline   Reply With Quote
Old 08-05-2010, 04:20 PM   #417
xray09ACT's Avatar
I just built mine from new.
I used o-rings that people use for the front driveshaft stops inside the cups of a tamiya mini diff.
I too found that it leaked a little from around the pulley, so i just smeared some associated diff grease on the gaket, i think its too thin or worng type of material. seemed to fix the leaking. When i say leaking, i probably mean a small seeping thats all.
In terms of the 50mm shafts I have no idea what the issue is. I have installed it in the T3 with 52 mm shafts and the only time I can get it to bind is if the camber is greater tha 4.5 deg and the wheel is lifted about 15cm from level. eihter on of these i can't see me either using or happening in a race situation, unless i crash it, which means the gear diff binding will be the least of my worries. I am using the standard xray blades though which I have found are thinner than some after market types.
ACE Hobby Australia | Monaro models
TEAM Associated TC6 | LRP | LRP
TEAM Associated TC6 | Nosram | Nosram
TEAM Associated 12R5.1 | LRP | LRP
xray09ACT is offline   Reply With Quote
Old 08-06-2010, 10:57 AM   #418
I just ordered a Spec R gear diff for my 416 WE along with the universals and 44mm spring steel shafts.
Cant wait to test it out.
Turillo is offline   Reply With Quote
Old 08-07-2010, 11:54 AM   #419
Originally Posted by P.I.M.P View Post
hi guys just letting you know that is fairly easy to fit the photon gear diff into the tamiya 416 and the xray t3 without mass mods.for the 416 you need the photon swing shaft protectors and you need to mod the ball diff pullly aswell and for the t3 its a pully mod and then it fits fine.....Attachment 620372
Attachment 620373
I just tried to fit the photon diff to a T2009, went in okay with pully mods but the balls on the end of the dogs bones are to big, just incase any one tried it!!
michael.branth is offline   Reply With Quote
Old 08-07-2010, 12:03 PM   #420
Default parts left over::
Just installed my spec R diff and I have notice two clear washers? do this go behind the drive shaft pins or should it be the thin metal ones?
looking good, only got 60wt shock oil in at moment for 10.5 rubber/carpet, do you think it will be any good?
cheers
