Spec-R Gear diff review >
Old 07-30-2010, 07:48 PM
  #391
kschu's Avatar
Trader Rating: 16 (100%+)
top photon diff fit bd5 as well...
kschu is offline
Old 07-31-2010, 03:59 AM
  #392
Originally Posted by P.I.M.P View Post
hi guys just letting you know that is fairly easy to fit the photon gear diff into the tamiya 416 and the xray t3 without mass mods.for the 416 you need the photon swing shaft protectors and you need to mod the ball diff pullly aswell and for the t3 its a pully mod and then it fits fine.....Attachment 620372
Attachment 620373
HI Dude,
do you have any pics of the T3? I presume this also means it will be fine in T2 008/009?
cheers
michael.branth is offline
Old 07-31-2010, 09:03 AM
  #393
Ran my spec-r diff for 5 heats and a final and it didn't feel smooth after. Stripped it down and the shims have worn really bad and the 2 pins are worn to. Does anyone know where i can get new shims and pins in the UK? Apart from the wear the diff ran great and did not leak i was using a 13.5T.
BILKO1 is offline
Old 07-31-2010, 01:05 PM
  #394
getpip's Avatar
getpip is offline
Old 07-31-2010, 11:08 PM
  #395
Super Moderator
Grizzbob's Avatar
No idea about who you can get them from in the UK, but just an fyi, the part number for the replacement gearset(which includes new shims & o-rings) is SPR010-G, & if you're willing to look overseas, Speedtech RC has them in stock.
Oh, & now that I've run it in my car, I think it's time I shared my thoughts on it, & I must say, I was VERY pleased with the feel of it. Started early in the day with some Associated 80wt shock oil in it, but it felt a bit odd(almost thought maybe it was diffing out), so I looked to use something else, & got some Sportwerks Diff Oil(which the bottle says is 100wt, but it flows more like 40-50wt shock oil), & didn't realize it till it was going in, so I decided to go ahead & try a practice run with that in it. And I must admit, it WORKED, car felt WONDERFULLY planted, & I ran it that way all night, & the car handled GREAT all night(oh, & this is on a carpet track, though the carpet is pretty worn & doesn't have much of a groove, so grip is at a premium)....
Grizzbob is offline
Old 07-31-2010, 11:32 PM
  #396
Trader Rating: 48 (100%+)
Originally Posted by InspGadgt View Post
Anyone make one for the Corally?
+1
Anyone know if one of these fits a Corally Phi 09?
crazydave is offline
Old 08-01-2010, 12:14 PM
  #397
SlideMasteR's Avatar
Q, what wt or cst oil would be run on a low traction asphalt condition and why?
SlideMasteR is offline
Old 08-01-2010, 12:46 PM
  #398
Skiddins's Avatar
http://demonpowerproducts.co.uk/adva...cturers_id=163
Are you sure you built it correctly?
Skiddins is offline
Old 08-01-2010, 01:57 PM
  #399
STLNLST's Avatar
Trader Rating: 22 (100%+)
I would TQ all the time if there was a gear diff made for the Cyclone TC
STLNLST is offline
Old 08-02-2010, 07:38 AM
  #400
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Anyone try to to use antiwear grease instead of oil?
hotdognobun is offline
Old 08-02-2010, 08:03 AM
  #401
JRXS_chris's Avatar
Originally Posted by michael.branth View Post
HI Dude,
cheers
Yes, it fits in the 09 no prob. You will however need to use the 38t conversion (Front Pulley and Longer Belts) and 50mm rear driveshafts.
JRXS_chris is offline
Old 08-02-2010, 08:12 AM
  #402
I ran mine last weekend for our big meet and it was smooth as butter all weekend. No leaking and used 80wt AE shock oil. I'm happy. I'm going to get one for the front as well and try it out with some heavy diff oil.
Should be as good as a spool without the front end abuse. We'll see
JoeGlover is offline
Old 08-02-2010, 10:22 AM
  #403
Attachment 620373
What xray part do I need for the t2/t3 mod for the Photon Gear Diff?
hardmankam is offline
Old 08-04-2010, 05:40 AM
  #404
kschu's Avatar
spec-r geardiff in stock now...
kschu is offline
Old 08-04-2010, 06:22 AM
  #405
BILKO1 is offline
