Spec-R Gear diff review > Spec-R Gear diff review
Old 07-25-2010, 05:00 AM
  #361
Default serpent front and rear gear diffs???
HI All,
I ve seen that serpent are testing with gear diffs front and rear, has any tried this and what would you expect to happen? Since no one really ran balls diff all round unless it was high grip carpet I just wondered if any one had been trying this??
Serpent seam to think its worth a try!!
cheers
michael.branth is offline
Old 07-25-2010, 05:06 AM
  #362
stiltskin's Avatar
Trader Rating: 103 (100%+)
Originally Posted by michael.branth View Post
HI All,
cheers
Gear diff in the front with a thicker oil will give more corner entry steering than a spool without sacrificing the strong pull out of the corner that the spool has.
stiltskin is offline
Old 07-25-2010, 06:08 AM
  #363
PitNamedGordie's Avatar
I was wondering the same thing. I'm seriously thinking of trying this out. I know I'm one of the few people left who likes running a one way more so than a spool. But since the spool is what was included I have stuck with it. So how thick should the oil be if running the diff up front...30K?
PitNamedGordie is offline
Old 07-25-2010, 06:24 AM
  #364
stiltskin's Avatar
I have the micro pro diff, so I'm not sure how much difference there would be, but I ran 50k up front and felt that it was too soft. I think somewhere between 70k and 100k will work, depending on grip level and track layout. 50k didn't pull through the chicane very well and felt like the front end was floating through. I only ran it for about 10 minutes though, so maybe car setup could have corrected that. IDK.
Old 07-25-2010, 10:53 AM
  #365
Yeh, I am with you, I ve never really liked driving with a spool so an alternative is of interest to me. Not sure how to test as I only have 1 gear diff, I think I will start with a ball diff in the front but run it v tight ( 8th of a turn back off locked)
let me know if any one else ends up doing similar,
cheers
Old 07-25-2010, 01:48 PM
  #366
Skiddins's Avatar
Provided it doesn't lift it's inside wheel etc and lose some of the exit grip due to one of the wheels spinning up.
Skiddins is offline
Old 07-25-2010, 02:00 PM
  #367
stiltskin's Avatar
I agree. I know that it's going to lose some of the forward traction, but it won't "diff out" as easily as a ball diff with the thicker oils. I'm already seeing that to be true. The car is easier to drive as well. The clock wasn't on to show definitive results but the car definitely felt better. Still more testing to do.
Old 07-25-2010, 02:44 PM
  #368
I ran the gear diff in the rear for the first time this weekend with 1000cst exceed oil. The car felt like it had slightly more steering at corner entry and about the same steering coming out of the corner.
If the inside wheel got too light however the car would tend to diff out and drive inconsistantly from time to time. I know you can remidy this with thicker oil but I don't want to loose the entry steering...
Have you guys tried a higher rear roll centre to stop the inner wheel from lifting or more droop at the rear?
Just some initial thoughts. Lots more testing to be done yet.
Mike
ixlr8nz is offline
Old 07-26-2010, 01:39 AM
  #369
Benzaah's Avatar
Trader Rating: 21 (96%+)
At practice yesterday one of The local Xray mod guys broke 2 of these Diffs running 4.5 Lipo. Wish Xray would hurry up and sort one out for us T3 users.
Benzaah is offline
Old 07-26-2010, 05:00 AM
  #370
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
This was nothing to do with the quality of the diffs, he was just seeing how far he could push it to get the best results He sanded the gears quite heavilly to free it up a bit more and this was what caused the problems
Yokomo_Ant3 is offline
Old 07-26-2010, 06:05 AM
  #371
Originally Posted by MoonTrap View Post
Is there any plans for a gear diff for the TC5?, or does anyone know of a diff that fits the TC5?.. I am able to change the pulley orientation on the layshaft to match other cars, but i am needing to find a diff that fits the back..
Hi Moontrap...
A guy im racing with has a TC5, with a photon gear diff.... Its basically fits... Stick a few shims on it... Job done.....
CouldbeFaster is offline
Old 07-26-2010, 07:29 AM
  #372
So is any oen near a base set-up for diff oil with front and rear gears?
I am thinking 100wt front 60wt rear for 10.5 rubber tyre carpet?
Old 07-26-2010, 07:35 AM
  #373
Try 300,000 Front and 100,000 Rear
Medium Traction carpet
008-Racer is offline
Old 07-26-2010, 08:54 AM
  #374
do you mean 30'000 front, I can not find any 300'000 and that would make the front looser right?
cheers
Old 07-26-2010, 08:57 AM
  #375
cheers
Xray do a 300,000 diff oil and 100,000 diff oil
We had a chap at a local indoor track supposedly running the above weights and looked very good
Front was stiff but would turn nice and slowly, and the rear felt like a normal diff
