Old 07-12-2010, 06:23 AM   #271
STLNLST's Avatar
Trader Rating: 21 (100%+)
Will there ever be other cars added to the make?? Would love one for my Cyclone
STLNLST is offline   Reply With Quote
Old 07-12-2010, 07:16 AM   #272
M-Technic's Avatar
Trader Rating: 15 (100%+)
Email Spec-R, I don't believe they are on these forums.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-12-2010, 03:09 PM   #273
mac853's Avatar
Try also in Facebook, i saw in hours ago even he's already on in the chat!
mac853 is offline   Reply With Quote
Old 07-12-2010, 04:40 PM   #274
redskin666's Avatar
Thumbs up
One for the cyclone would be cool. Or 2 even, you could thinker oil in the front so is stiffer than a ball diff, but has the give that a spool doesn`t!!!!!
redskin666 is offline   Reply With Quote
Old 07-12-2010, 05:26 PM   #275
JayL's Avatar
not sure why they would make a product for a car whose replacement has been announced, won't be compatible and is due soon......
sorry buddy
JayL is offline   Reply With Quote
Old 07-12-2010, 07:02 PM   #276
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
416 one will fit the TCX if you play about with front pulley and belts (from 416)
also if you have a huge amount of shims (3mm) then you could space it out for the std cyclone, and then change to the 416 belts and front spool (again another 3mm of diff shims needed)
bare in mind if you do it that way for the STD cyclone yourll need the pro 4 driveshafts (same length as the new tcx ones)
hope that helps
luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 07-13-2010, 12:30 AM   #277
frank b's Avatar
i have been running the gear diff on my xray t3 for the last 4 weeks and it has been flawless. i was at a two day race were i ran the car in two classes and never had a problem all weekend. the only issue i have is that there is still oil coming out of the diff, so to every one don't over fill the diff like i did. i have fixed the problem and no more issues.
frank b is offline   Reply With Quote
Old 07-13-2010, 04:43 AM   #278
SlideMasteR's Avatar
where are you guys getting the diff oil, or can you use shock oil rated 80 - 100 ?
Assembled mine last night with 100wt shock oil and it all looks and feels really good and smooth, cant wait to track test it ?
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 07-13-2010, 07:27 AM   #279
M-Technic's Avatar
Buy nitro diff oil. That shock oil you used is very thin. We are pretty much all running 500-2,000wt.
Old 07-13-2010, 03:15 PM   #280
frank b's Avatar
i used xray 1000wt diff oil and you will be able to get it from your local hobbie shop !!!!!
Old 07-13-2010, 05:48 PM   #281
My Spec-r diff turned up today (thanks kschu) i'm fitting it into the rear of my T2 009 which has been converted to the 38t pulleys. I've read through a few posts and people recommend changing the shims for bigger ones can you give me make and part numbers and possibly a UK supplier for these shims.
I run on a small indoor tight carpet track with medium grip which gets better after a few heats. I run 13.5 or 10.5, what would be a good starting point for the diff oil? preferably in cst as wt can vary so much.
BILKO1 is offline   Reply With Quote
Old 07-13-2010, 06:58 PM   #282
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Thanks for your support dude....
Hope you enjoy the gear diff....
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-13-2010, 07:02 PM   #283
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
At the recent MSRA Beat the Heat race in Memphis I ran 100 wt Losi oil in mine and another front runner ran 1000wt Mugen diff oil. This was on 150 ft straight with unlimited esc 17.5's. I ran the diff with the stock innards, but it leaks after a few runs. I gotta get that fixed. I smeared 6636 AE diff grease on the seals and around the outdrives, but it still leaked after the first day of racing. I heard I should try green slime, but I haven't been able to try it yet. It leaks around the outdrives, but not through the pulley/gasket.
Old 07-13-2010, 07:35 PM   #284
M-Technic's Avatar
Just run the stock shims. I tried adding 0.1mm shims to mine and it bound up the gears.
Old 07-13-2010, 08:07 PM   #285
yes! u must check the shim around 10pack battery carefully,
because the size and the thickness not enough, so the shim will become deform...
i prefer start with kyosho #1000-3000 gear diff oil.
teamsanwa is offline   Reply With Quote
