Old 07-05-2010, 02:22 AM   #196
RC MARKET's Avatar
Originally Posted by immrwright7 View Post
Also what type of grease? How does this gear diff effect the handling?
around 1k-5k oil
RC MARKET is offline   Reply With Quote
Old 07-05-2010, 03:48 AM   #197
Eirik's Avatar
Originally Posted by RC MARKET View Post
around 1k-5k oil
Hello Mister,
I just placed an order from your shop and was wondering when you will have them back inn stock?
Thanks,
Eirik Andreassen
Eirik is offline   Reply With Quote
Old 07-05-2010, 04:12 AM   #198
Born2Run's Avatar
Instead of the NT1 rear diff. has anyone tried to modify the 3Racing Rear Diff to use on T2 or T3?
Whatever
Born2Run is offline   Reply With Quote
Old 07-05-2010, 04:48 AM   #199
niznai's Avatar
Originally Posted by BlackedOutREVO View Post
Mods to fit the pulley, but other wise its suposed to fit fine. Im ordering mine in another week or two and will do a little write up if no one else has by then
http://www.rctech.net/forum/7121865-post1660.html
I'm a bit confused by previous posts, is the gear diff to be used on the rear only or can it be used on the front as well? Also, am I right to believe that when used on the rear the front needs to run a spool?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-05-2010, 04:55 AM   #200
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Corona000 View Post
can i get one of the spec r diffs for axray 007?
The two parts that Spec-R has would require you to change your drive axles in order to use the larger 3.5mm ends instead of the 3.0mm ends.
If you change the drive axle to the type of parts used in the T2'008/009 or T3 then you could install the 34 tooth gear diff marketed for the Atomic VM2 mini touring car. Their car accepts XRay 34 tooth diffs (I have my old diff from my T2'008 in mine).
Part Number: VM-067
Link: http://www.egrracing.com/shop/gear-d...ii-p-3774.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-05-2010, 04:56 AM   #201
hanulec's Avatar
it can be used in either or. i think the ideal location is in the rear. if you use it in the front to replace a spool then you must use some thicker lube like people do in NItro Touring.
Old 07-05-2010, 05:15 AM   #202
It is the euro version 009,only changes are ecs frnt drives,Thanks
tino is offline   Reply With Quote
Old 07-05-2010, 05:24 AM   #203
niznai's Avatar
Has anyone tried to use the front NT1 gear diff ? Seems easier to modify and adapt to accept a pulley.
Team Greasy Weasel
Old 07-05-2010, 09:56 AM   #204
M-Technic's Avatar
Trader Rating: 15 (100%+)
Whatever your preference is.
Locally, we use it in place of the ball diff in the rear and continue to run a spool up front.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-05-2010, 01:17 PM   #205
Johnny Wishbone's Avatar
I haven't, and I don't have one to look at, but my question would be if there is enough extra material left once the gear is removed to be able to attach the modified diff gear?
Old 07-05-2010, 11:34 PM   #206
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
You can use it where ever. The rear is where most will want to use the gear diff though, with a spool in the front
I wonder what the differences are too. Because it looks like the nt1 front diff is smaller then the rear diff, which might be easier to mount the pulley to?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-06-2010, 12:51 AM   #207
niznai's Avatar
thank you 'revo.
I had a closer look and the front NT1 diff lends itself to installing the pulley easier, but the diff outdrive necks are longer, so it needs machining and very close at that. I have a lathe, so I can do it, but it is not sure it will be easier in the end. If I decide to attempt it in the end, I'll post some comments.
the rear diff is easier in that all you need to do is to remove the pulley moulded on top of the bevel gears' casing. The rest remains unchanged.
I have both front and rear NT1 diffs and took some measurements so I am pretty sure of my conclusions.
One question though. In the diff kits there is some paper that looks like gasket paper but in the Xray manuals (NT1) there is no suggestion of what to do with it. Anyone care to comment?
Team Greasy Weasel
Old 07-06-2010, 01:07 AM   #208
Suspended
thank you 'revo.
sorry, i am not sure for that??
begintravel55 is offline   Reply With Quote
Old 07-06-2010, 02:03 AM   #209
niznai's Avatar
The front gear diff doesn't have the pulley moulded into it but it attaches with the diff screws. The front pulley is smaller too.
begintravel, I am not sure what you're asking.
Team Greasy Weasel
Old 07-06-2010, 07:15 AM   #210
Default gear diff for T3 38T
Ask help of dimension x,y as photo?
It is gear diff for T3 38T, i want to use it in TC5R.
But i need to know both dimensions of x, y before i buy this.
mos-leung is offline   Reply With Quote
