Old 07-04-2010, 12:45 AM   #181
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by BlackedOutREVO View Post
Cyclone needs a front nt1 diff and your dialed. And crapricorn gears to shave weight out of it (28 grams less). That's what I'm going to do but rear nt1 diff is what goes in the t3 should be the dialed gear diff that will hold up in mod
Isn't that nt1 diff sort of heavy? The spec diff should work if the nt1 fits./
STLNLST is offline   Reply With Quote
Old 07-04-2010, 01:27 AM   #182
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
That's why I said crapriorn light gears lol. You can get lightened outdrives Also and it should end up pretty light
But no the nt1 diff that fits the cyclone is the front which I'm pretty sure is smaller then the nt1 rear diff which is what fits the Xray. I'm not sure how much different the front and rear diffs are though
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-04-2010, 10:53 AM   #183
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by immrwright7 View Post
Thanks for the input^^
So are you running the gear diffs in both the front and rear? Also did you have to alter or completely change the dogbones?
I have my Atomic gear diff Just in the rear. I run 50mm dog bones in the rear of the T3 (and 50mm ECS in the front).
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-04-2010, 11:13 AM   #184
Also what type of grease? How does this gear diff effect the handling?
immrwright7 is offline   Reply With Quote
Old 07-04-2010, 11:37 AM   #185
niznai's Avatar
Is the rear NT1 a direct fit in the T3, or does it need some work?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-04-2010, 11:45 AM   #186
Mods to fit the pulley, but other wise its suposed to fit fine. Im ordering mine in another week or two and will do a little write up if no one else has by then
http://www.rctech.net/forum/7121865-post1660.html
Old 07-04-2010, 12:04 PM   #187
hanulec's Avatar
500 cst XRay Silicone Oil (running on carpet will need much thicker oil). Handling wise - there was much more rear traction under hard acceleration, and greater car rotation off power freeing up the car.
Old 07-04-2010, 12:34 PM   #188
Hey thanks i'm planning on running my diff on asphalt with my 13.5 setup.
Old 07-04-2010, 02:12 PM   #189
STLNLST's Avatar
Why not just get the Spec diff that JL has?
Old 07-04-2010, 02:49 PM   #190
hanulec's Avatar
It was good enough for Marc to win the Worlds with!
Old 07-04-2010, 03:50 PM   #191
JLTrinity's Avatar
Hello,
What silicone oil is used to the rear gear diff to run in asphalt?, 20.000 cps like tourings Gp? or 2000-3000 cps? thanks
JLTrinity is offline   Reply With Quote
Old 07-04-2010, 03:55 PM   #192
Which gear diff for the 009 if any?Thanks!
tino is offline   Reply With Quote
Old 07-04-2010, 04:04 PM   #193
hanulec's Avatar
Originally Posted by JLTrinity View Post
Hello,
500 cst is what I used yesterday.
There are models available for either 34t or 38t pulleys. Which are you running??
Old 07-04-2010, 04:20 PM   #194
How do you know it was a totally stock spec r diff? Lots of people have issues with them in mod and that's all I will run. So I will spend the little extra and have a bomb proof diff.
And Clint jays doing the same thing I am lol. So you can ask him why he doesn't like it
Old 07-05-2010, 12:59 AM   #195
can i get one of the spec r diffs for axray 007?
Corona000 is offline   Reply With Quote
