Old 07-02-2010, 09:26 PM   #166
Trader Rating: 18 (100%+)
Originally Posted by Matt Howard View Post
Stronger bumper? I heard you're the bumper durability tester
Actually, he is testing REAR bumpers as he is getting run over a bunch lately.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 07-02-2010, 09:29 PM   #167
Matt Howard's Avatar
I'm sure he was "testing"
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-02-2010, 10:22 PM   #168
Thinking about running an spec r diff in my xray what all do I need to have it running right? Also should I run gears in both front and rear of the car?
immrwright7 is offline   Reply With Quote
Old 07-03-2010, 05:07 AM   #169
hanulec's Avatar
Trader Rating: 27 (100%+)
Which XRay do you have? Does it use 34 tooth or 38 tooth pulleys?
I'll be trying my new 38 tooth gear diff in the rear of my T3 today. Running 500 cst XRay shock oil in it to start on asphalt.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-03-2010, 06:06 AM   #170
rcstunt101's Avatar
Trader Rating: 16 (100%+)
Any idea of options to get a gear diff for the TC5R?
Associated TC5R
Associated B4
Yokomo B-max4
LRP, Intellect, Futaba
rcstunt101 is offline   Reply With Quote
Old 07-03-2010, 10:49 AM   #171
STLNLST's Avatar
Trader Rating: 21 (100%+)
With Norcals name being changed to "HACKCAL" we all will need some new bumpers.
Only testing my patience
STLNLST is offline   Reply With Quote
Old 07-03-2010, 02:36 PM   #172
Hey, if you're slower,...get out da way
RCTech #361
Old 07-03-2010, 02:39 PM   #173
STLNLST's Avatar
You would be blasted out here too.....there's NO LOVE on the track.
Wish there was a gear diff for the HB car.....HINT HINT
Old 07-03-2010, 02:41 PM   #174
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Run a Xray diff lazy. Make it work
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-03-2010, 03:12 PM   #175
STLNLST's Avatar
I'll probably run the Xray....lol
Old 07-03-2010, 11:10 PM   #176
I'm running a T3 at the moment with 38t pulleys
Old 07-03-2010, 11:35 PM   #177
hanulec's Avatar
I think most people are only using the gear diff in the rear right now. You could use the gear diff up front to replace the spool if you use some very thick silicone lube -- like you find in Nitro Touring Cars.
My first outing with the gear diff went well (but not for my modified car -- that is another story). Going back to back on a ball diff to the gear diff when running an 8.5T Speed Passion motor along with an aggressively configured Tekin RS Pro (using my standard 13.5T config) I found that the gear diff was not only to take all of the power I could throw at it - but it also made the car handle more predictable when just hammering the throttle, especially out of a hard 180 degree turn.
I did experience one issue with the gear diff -- but all in all it isn't a problem with the product per say. On the third or forth lap when running my modified car I experienced a blow over, which made my smash into a cement brick wall at full speed while sliding on the roof. Basically the car is gone - graphite chassis and top deck are broken along with a lot of bent metal bulkheads. One of the bevel gears got a slight chip during this crash. This produced a jerky diff action that I was able to fix by swapping out a the bevel gear with a spare part that I had ordered. Amazingly, the gear diff mostly survived the accident. I ran the gear diff the rest of the day in a 13.5T club race.
At the race today there were a few other T3 runners who were testing with the Spec-R gear diff too -- and even more racers that wish they had one. I really think this product is going to be a hit.
Old 07-03-2010, 11:43 PM   #178
Thanks for the input^^
So are you running the gear diffs in both the front and rear? Also did you have to alter or completely change the dogbones?
Old 07-04-2010, 12:30 AM   #179
STLNLST's Avatar
So since it seems that there might not be a gear diff for the HB car soon....could the Xray be made to fit? It has the closest pully to the HB car.
Old 07-04-2010, 12:41 AM   #180
Cyclone needs a front nt1 diff and your dialed. And crapricorn gears to shave weight out of it (28 grams less). That's what I'm going to do but rear nt1 diff is what goes in the t3 should be the dialed gear diff that will hold up in mod
