Futaba S9550 Servo >
Futaba S9550 Servo
Futaba S9550 Servo
Old 05-11-2004, 05:10 PM
TFR
TFR's Avatar
Futaba S9550 Servo
Hey guys, I know alot of you own this servo. I just got this servo and when I turn the servo by hand, the gears inside feel very gritty. I took it apart and nothing is binding but still feels very gritty. Is it suppose to be like that when you first got it?
TFR is offline
Old 05-11-2004, 06:21 PM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Mine was a hair gritty before it's first run, now it's fine...
Randy Caster is offline
Old 05-11-2004, 07:50 PM
eeyan's Avatar
I experienced the same problem, but it does not seem to affect performance... My newest one still feels gritty after 2 races (I have 3 of these so I'm sure it's normal...)
eeyan is offline
Old 05-11-2004, 08:17 PM
TFR
TFR's Avatar
Does it also make a loud grinding noise of your newest servo? When I turn the servo by hand, not only is it gritty but it was loud. Not the buzzing sound tho...
TFR is offline
Old 05-11-2004, 08:26 PM
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
I would try it first and if it don't work right you should know if it is working.
wyd is offline
Old 05-11-2004, 11:55 PM
evaa's Avatar
i'd like to take the opportunity to ppost this question, here it goes, when i visited the futaba site there was a description of the servos, the 9450 and 9451 were described as "DIGITAL SERVOS", while the 9550 was described as a "DIGITAL WING SERVO"
what gives? whats the difference between digital and digital wing servos?
tanx guys in advance
evaa is offline
Old 05-12-2004, 12:12 AM
The 9550 is a low profile servo so you can get more space to lay electronics flat in crouded sedan chassis'.
Old 05-12-2004, 12:18 AM
Regional Moderator
disaster999's Avatar
the 9550 is design for airplanes, so they could mount the servo on the wings of the airplane, hence "digital wing servo"
disaster999 is offline
Old 05-12-2004, 01:06 AM
evaa's Avatar
tanx for the info disaster999
evaa is offline
Old 05-12-2004, 02:55 AM
Registered User
Suradaj's Avatar
Mine was never like that new.
Suradaj is offline
Old 05-12-2004, 07:30 AM
ICEMAN's Avatar
got one in my XRAY T1M, neevr had a problem.
ICEMAN is offline
Old 05-12-2004, 11:27 AM
Danny B's Avatar
Trader Rating: 23 (100%+)
Default metal gears
If you have never had a metal gear servo before, this one will probably feel "gritty" All metal gears are like that, they will get a little better as the gears wear in, also they will be louder than a standard servo.
It is a great servo. I have never had a problem with mine.
Danny B is offline
Old 05-12-2004, 11:35 AM
jag88's Avatar
The 9550 is a "high current drain" (at start up) servo. Have any of you noticed less run time or less motor performance in your electric touring car/buggy ? Do you run a reciever pack ?
jag88 is offline
Old 05-12-2004, 11:56 AM
Fire's Avatar
the drain is high compare to other non digital entry level servos, but it's like nothing compare to the motors a glitch from crashing or hitting a pipe may lost more power than using the servo. also with the GP cells you should be able to make run time for 5 min mod race, and if you don't race run time doesn't really matter at all
i think receiver pack is more for assisting the power to the receiver and servo during hard acceleration, or make up for the voltage in 4 cells racing
Fire is offline
Old 05-12-2004, 12:16 PM
micmc's Avatar
I Have it too and i can say always positiv aspects about it..
micmc
RC Car Net
Sorry for my bad english
micmc is offline
