Problem with Reedy Quasar >
Old 05-11-2004, 01:14 PM
sparky123's Avatar
Default Problem with Reedy Quasar
i have recently purchased the standard reedy quasar charger and have tried to use it to charge my batteries; however, when i plug in the battery (an epic 3000mah nimh stick with tamiya connector), nothing happens, none of the lights come on and the fan doesn't switch on at all, upon pressing the start button the thing just sits there doing jack ####. does anyone have any idea as to what i'm doing wrong?
(also when i plug in my 1500mah nicd pack the fan seems to switch on but the lights again fail to activate).
thanx in advance
jim
sparky123 is offline
Old 05-11-2004, 01:48 PM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Give Associated a call and see what the issue could be.
Cain is online now
Old 05-11-2004, 02:24 PM
sparky123's Avatar
Default Re: give them a call
the only problem with is i live in the uk and so can't really afford an international call from my mobile.!!
Old 05-11-2004, 03:16 PM
lmunno's Avatar
Have you tried to e-mail them????
lmunno is offline
Old 05-11-2004, 07:02 PM
popsracer's Avatar
sparky123;
Make sure that the alligator clips are making good contact inside the Tamiya Plug.
A bad cell or broken bar in the pack would cause the same problem.
Double check the charger with a known good pack (borrow one if you have too). Otherwise I would say the Charger is defective.
popsracer is offline
Old 05-12-2004, 12:48 AM
sparky123's Avatar
Default thanx
this sucks, i just tried it with a friends sanyo gp3300 pack it did exactly the same.
o well
i'll try emailing them and after that i'll probably have to send it back.
cheers for the advice guys.
jim.
Old 05-12-2004, 01:24 AM
Cole Trickle's Avatar
Have you purchased it overseas or in UK? CML distributes them in the UK, so if you got it overseas, it might worth paying for repair via CML to save shipment and especially time. Do some research to find the best/easiest/cheapest solution.
Cole Trickle is offline
Old 05-12-2004, 04:24 AM
Hardriven RC's Avatar
Check the Novak site!! They are recaling all Quasar chargers!!
Hardriven RC is offline
Old 05-12-2004, 04:37 AM
sparky123's Avatar
are you so sure about that?
i know that there is a recall on the quasar pro 611, but not the standard one, and i thought that reedy and ae made the quasar not novak.
jim
Old 05-12-2004, 08:24 AM
jim
OOps, your right. It is ofcours Reedy/Associated that recalls them.
My bad.
