Old 05-27-2010, 01:45 PM   #1
Default ESC PROBLEMS
Can anyone tell how I could now if my esc damage
My buggy can go forward
firereds is offline   Reply With Quote
Old 05-27-2010, 01:48 PM   #2
Joel Lagace's Avatar
yes
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 05-27-2010, 01:55 PM   #3
Can u tell me how please
Old 05-27-2010, 02:21 PM   #4
I was being a smart ass.. you need to give us all kinds of info i we will have any chance of diagnosing your problem blindly over the internet..
So lets start off with a few questions:
-How do you know you have an ESC problem? What is it not doing properly?
-What ESC,MOTOR and Battery are you using?
-What are you using it in?
-Whats your gear ratio?
-Is your drive train free?
-Do you have proper gear mesh between the pinion and spur gear?
-Did you get it wet?
-Does it smell burnt?
-Does the motor smell burnt?
-Does it light up any of its lights?
-Does the motor rotate at all?
-Does the servo operate?
-Are all the wires securely plugged in or soldered?
-Have you tried to reprogram it?
Anyway give us as much info as you can...
www.rcottawa.com
Old 05-27-2010, 09:50 PM   #5
Toh WL's Avatar
anyone could help to suggest if u give detail on the prob. coz sometimes some are common prob anyone would have some workaround.
Toh WL is offline   Reply With Quote
Old 05-28-2010, 06:44 AM   #6
Timbulb's Avatar
rubber boots
Timbulb is offline   Reply With Quote
Old 05-28-2010, 08:09 AM   #7
I am new to the rc world so i bought a cheap electric buggy
MAX 4
ESC LM-406FB
MOTOR- dont know
anyways the servo works fine the reverse works fine as well , the problem is
i cant get any forward movement , when i try to put it in forward the led light on the esc dies, but it works in reverse
Hope that helps so that u can help me
Old 05-28-2010, 08:21 AM   #8
unfortunately your dealing with crap. no offence. ITs no name nock of equipment.
Hopefully! you have manuals with the ESC? Your going to have to reprogram the ESC. IF this arrived to you new in box and never used, its possible the Radio and ESC are simply not setup correctly.
I found your ESC here: http://www.halleyrus.com/Hobbies/Par...or+Truck+&+Car
But i cant find a manual for it. You need to confirm that blue wire is going to negative on the motor and yellow wire is going to positive on the motor. Best thing is to reset the radio and reprogram the ESC. IF still no got try reversing the throttle channel on the transmitter and then reprogram the esc..( again your transmitter manual will explain this)
www.rcottawa.com
Old 05-28-2010, 08:23 AM   #9
I'm guessing that the esc needs to be recablirated with the radio. Try to find a setup button on the esc. I haven't been able to find a manual for it unfortunately.
Threg is offline   Reply With Quote
Old 05-28-2010, 08:30 AM   #10
Thanks Guys
But it was a rtr rc buggy and it worked fine when i first got it used it about 2 times and it freaked out so how to re program it, and if that does not work what can i do
Old 05-28-2010, 08:33 AM   #11
if it wont reprogram take it to a local hobby shop and buy a new ESC. Novak,tekin,speedpassion,lrp ect ect the namd brands
www.rcottawa.com
smoke comming out of titan 550 motors on erevo after esc problems revman Electric Off-Road 10 05-15-2010 07:22 AM
novak motor +lrp esc problems lewis666 Electric On-Road 6 04-19-2010 10:54 AM
eZRun ESC problems Flatty Radio and Electronics 7 11-13-2008 10:00 AM
ESC Problems RompingDonkey Electric On-Road 9 12-18-2005 12:40 AM
