TA04 Weight Reduction >
Old 05-09-2004, 09:08 PM
lrdars's Avatar
Default TA04 Weight Reduction
I need to reduce the weight of my car TA04 to as close to 1500g as i can. I have the racing hub set, sway bar at the front.
I have cut 2 holes in the section unber the batteries about the size of a AU$ 50 cent piece. What else can i do............
Drill more holes????
Don't want to spend any move if i can
_LRDARS
lrdars is offline
Old 05-09-2004, 09:10 PM
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Do you want to keep as TCS rules or open rules for any club race?
OVA is offline
Old 05-09-2004, 09:16 PM
Entropy's Avatar
Delrin outdrives save you 15gm on the rear diffs (original are 30gms)
Other heavy stuff to shed are to invest on the low friction steering posts which are half the weight (around 6-8 gm savings compared to the stock steering posts).
If you're running the racing body mounts on the bumper, lose the front shock tower piece for the mounts if you're using the carbon towers.
Lose the center chassis post mount.
If its allowed, tape your batteries to your chassis instead of using the mounting clips and posts (they are very heavy!)
Change all your turnbuckles to aluminium or titanium ones, also change all your ball ends to aluminium ones.
I've done quite a few other stuff but these are the main ones I recall for now.
Entropy is offline
Old 05-09-2004, 09:25 PM
OVA
OVA's Avatar
Entropy I think he said ,he didn't want to spend any more money
OVA is offline
Old 05-09-2004, 10:12 PM
Entropy's Avatar
Ok here are the free lightweight hop-ups
Entropy is offline
Old 05-09-2004, 10:32 PM
OVA
OVA's Avatar
the is much better free items
OVA is offline
Old 05-09-2004, 11:29 PM
lem2's Avatar
Default Lightweight
here is what you do, do away with the batter post and just use tape! place holes on the spur, remove the center post but you may have flex problems, if you look in the pic I use 2 upper decks!
Look
lem2 is offline
Old 05-09-2004, 11:32 PM
lem2's Avatar
Default lightweight
you can also enlarge the holes under the motor, remove the inside of the arms(if your using graphite/hardened arms) and do away with the belt tensioner, i run mine een in Mod and it does not skip.
lem2 is offline
Old 05-10-2004, 12:09 AM
WC
WC's Avatar
Trader Rating: 28 (100%+)
How heavy is your shell? Shell alone might be 50g, but you could easily add another 50-70g in PAINT if you're not careful. Metallics & silvers are the main culprits.
WC is offline
Old 05-11-2004, 06:27 PM
lrdars's Avatar
Default Weight
Have drilled out about 15g i think it is time to get out the money. Is there are web site that tell you how heavy part are????
PS thanks for all the help
lrdars is offline
