Old 05-25-2010, 01:46 PM   #1
Default 3S in a HPI Sprint 2 Flux?
Hello
I have a HPI Sprint 2 Flux that I've been driving with 2S for a while now. And recently I also bought a Firestorm Flux. And for the Firestorm HPI says its OK to use 3S lipo: "With up to 8 NiMH cells or a 3S LiPo (11.1v)".
And since the Firestorm and the Sprint 2 Flux uses the same motor and esc, does this mean its ok to use 3S in the Sprint as well?
Very thankful for any answer!
Best regards,
Linus Sj÷berg
Sweden
Limpan is offline   Reply With Quote
Old 05-25-2010, 01:51 PM   #2
Chimer's Avatar
Trader Rating: 26 (100%+)
Are you drag racing? I don't understand why you would want that much power. I have heard that those electronics really don't like the power of a 3s and they don't last long if you use the 3s, just a rumor I heard, don't know if it's true or not.
AE:B5r,B5m,TC6.1,Team Losi:JRX-2,Tamiya Mercedes-Benz 1838LS,Traxxas Slash
Chimer is offline   Reply With Quote
Old 05-25-2010, 02:47 PM   #3
Why would anyone want more power? If you can give full throttle there is still room for more power!
After driving my Vorza with 6S at 60mph+ the Sprint 2 Flux seems very slow with its 30mph or so
TEKIN -> RC8Be * RC8Te FT Championship Edition
HPI Blitz ESE (MM Pro + 5700kv), HPI Sprint 2 Flux
Traxxas Slash 4x4 Ultimate, SANWA M11 2.4
Old 05-25-2010, 04:31 PM   #4
Chimer's Avatar
Crazy!!!!!!!!!!
I understand the need for speed. I was just wondering what you were doing with the car because you can have too much power for racing. Have fun.
Old 05-25-2010, 05:28 PM   #5
Morbo's Avatar
Do it!!
And show us videos and pics of the results!
All humans are vermin in the eyes of Morbo.
Morbo is offline   Reply With Quote
Old 05-25-2010, 05:46 PM   #6
Originally Posted by Morbo View Post
Do it!!
Are you saying that in a way like "Lets see this moron ruin his motor.."?
Old 05-25-2010, 07:35 PM   #7
PaPeRo's Avatar
The electronics could handle it but make sure your gearing is appropriate. I think your belts/pulleys may not be able to handle that power though, it's definitely worth a try if you're not racing and just bashing.
deans - dodgy electrics amps not sufficient
PaPeRo is offline   Reply With Quote
Old 05-27-2010, 11:11 AM   #8
Morbo's Avatar
umm..no?
Old 05-27-2010, 11:40 AM   #9
superspeed's Avatar
the flux esc & motor can handle 3S lipo, gearing is very critical and make sure you gear it properly.
superspeed is offline   Reply With Quote
Old 05-27-2010, 02:52 PM   #10
So should I go higher or lower in the gearing? (Higher or lower top speed)
Old 05-27-2010, 06:26 PM   #11
You can run 3s on sidewinder/hpi flux motiv with 5700, but your pinion has to be small.
rcracingzone is offline   Reply With Quote
Old 05-27-2010, 07:38 PM   #12
LOSI123's Avatar
Trader Rating: 63 (100%+)
the rear diff spider gears will spit it after a couple of throtle pulls. so i have seen anyway, good luck
LOSI123 is offline   Reply With Quote
Old 10-26-2011, 02:31 AM   #13
Zao18's Avatar
I am pretty doubtful that it can handle 3s. The hpi webpage for the Sprint 2 Flux mentions being 2s-compatible, but not 3s. Compare this to the e-firestorm page which actually says 2 and 3s compatible (it has a 4800 kv motor).
Also, fyi, this car has a 5900 kv motor in it, not a 5700 kv. Given that both the e-firestorm and the Sprint 2 have the same Vapor ESC in it, it's likely a case of the ESC can handle 3s, but the 5900 kv motor in the Sprint cannot and will overheat.
Oddly, after pouring through the manual pdf, I don't see it spelled out anywhere what max voltage lipo this car can handle. My advice, if you want to absolutely be sure, is to email HPI and ask.
Hotbodies D8T, Hitec 7955TG servos, "Clocked" Werks B5 w/ 2013 pipe, M2C 4-shoe clutch
Losi 810 buggy (converted Ten T), M2C Racing clutch, Hitec 7955TG servos, 125cc fuel tank
Spektrum DX3S w/ SR3300T receivers
Zao18 is offline   Reply With Quote
Old 02-24-2012, 01:52 AM   #14
Just picked up a 3000mah 40c 3s skylipo today and dropped it in my 1 week old Sprint 2 Flux, that's bone stock. Ran it tonight with the grip tires and it flew. I didn't have my temp gun or gps, but temps were not so bad. Maybe 130s on the motor and esc. If I had to guess, it was in the 60's for speed!
Losi Mini 8ight - CM2646, mamba max pro, Hitec 5245mg, OFNA Shocks
OFNA Hyper 9e, Bump Edition Low COG - MMM2650, Hitec 7955tg
OFNA Nexx 10sc - Tekin Pro4 4000, MMP, Savox 1258tg, Proline Powerstroke Shocks
HPI Sprint 2 Flux - Stock Castle motor/ESC with Porsche 911 body and Savox 1258tg
richmtb is offline   Reply With Quote
Old 03-19-2012, 10:37 PM   #15
Does HPI say it can run a 3S?
Why does no one know? Weird....
2010GTR is offline   Reply With Quote
Huge RC Sale Neverdone R/C Items: For Sale/Trade 48 03-22-2010 04:18 AM
