Old 05-25-2010, 12:02 AM   #1
old-man's Avatar
Default Motor cooling fan stops at full throttle.
Anybody noticed that the motor cooling fan almost totally stops turning when you apply full throttle? Mine does. This happens even with a freshly charged pack and the fan is connected directly to the battery terminal on the ESC.
I think it got something to do with the much powerfull magnetic field of the motor disrupting the less powerfull magnetic field of the fan.
Anyway to fix this?
old-man is offline   Reply With Quote
Old 05-25-2010, 12:12 AM   #2
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Anyway to fix this?
maybe can try put in other place ...where u place the fan ?? front or rear or top of the motor ?
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-25-2010, 03:09 AM   #3
Trader Rating: 10 (92%+)
Anyway to fix this?
how big is the fan?
I know when I used a big fan, it stopped when full throttle.
it slowed down slightly when I used smaller lower output fans.
captain stacker is offline   Reply With Quote
Old 05-25-2010, 04:18 AM   #4
LOSI123's Avatar
Trader Rating: 63 (100%+)
running brushless motor or brushed?, and what turn?
also what brand fan?
is it going very strong when not on throtle or weak fan?
what battery exactly, nimh or lipo?
LOSI123 is offline   Reply With Quote
Old 05-25-2010, 07:26 AM   #5
jonest's Avatar
Anyway to fix this?
Have u tried Yeah racing fan? Mine is ok.
jonest is offline   Reply With Quote
Old 05-25-2010, 09:35 AM   #6
The fan would stop in any circumstances that I have tried. I believe it the draw from the motor is quite big and the maximum throttle would almost drain all the voltage from the battery and the fan as a smaller draw would loose out to the bigger draw from the motor.
Happy RCing.
p.s. Old man, you can call me directly next time if you have questions like these.
mikecan8 is offline   Reply With Quote
Old 05-25-2010, 01:06 PM   #7
Toh WL's Avatar
i tried the yeah racing... sadly not much air compare with lrp fan.
Toh WL is offline   Reply With Quote
Old 05-25-2010, 07:33 PM   #8
jonest's Avatar
Which size? 25mm or 30mm? We're quite happy with the 30mm... but we are also using the Speedpassion heatsink on the motor.
Old 05-27-2010, 05:57 AM   #9
Toh WL's Avatar
i use the 25mm which comes with the heatsink.... cooling effect not so good n i lose a motor.
however i change to lrp which is good n i m happy with that n the heatsink is purely solid.
