Chasing Speed
#46
Originally posted by WC
sorry, any dyno reading is useful ONLY when there's a load on the motor. If there's no load there's no power generated by motor so its all a moot point.
If you want to make your 'dyno' current readings higher, just don't oil the motor bushings.
Main secret to success in 540 is clean driving. With 540 geared high, it takes so long to reach race speed after a smack you'll be losing 50' to the other guy for every time you hit. Just a few hits and you'll be a lap or 3 behind.
#47
the fastest 540's I've seen sure they were lightly oiled after each race but before that and after the motor had cooled down they were run completely submerged in CRC Lectra clean so all the crud was flushed out then flushed again until the fluid ran clear.
Oh and having enough batteries to only use them once a day and keeping them in the refrigerator over night and chilled at the track helps for more punch too but you probably know that already.
