Old 05-22-2010, 12:58 AM   #1
Default help with stripped screw...
hay sorry guys I dont know ware else to post this but I have a stripped screw on my cyclone tc and I need to know how to get it out
I tryed putting solder in it and heating it up while the allen was in it but I dont wana runnin my car
any suggestions
Thanks,
kyle
winnppl is offline   Reply With Quote
Old 05-22-2010, 01:04 AM   #2
Armaan's Avatar
Trader Rating: 49 (100%+)
Two ways to skin it, Kyle.
#1 - Get a Dremel tool equipped with a cutoff wheel and slot the screw so you can jam a flatbade screwdriver in there and get the screw broken loose.
#2 - Use a drill with a drill bit that's slightly larger than the shaft of the screw to ease the pressure off the screw.
Either way, be careful....I wouldn't wanna ruin that carbon fiber chassis!
Good luck!
Armaan is offline   Reply With Quote
Old 05-22-2010, 01:18 AM   #3
find an old allen key and try to JB weld it in place. also, cant tell from the picture, but depending on your tools and on the screw you may want to try using a fresh machined hex wrench, like a new hudy, dynamite, or integy. i have found that a new hex wrench can get out some screws that may seem stripped but are just a loose fit on older tools or cheapy L (allen) wrenches.
there are also some screw extractors that look like counter-sinking bits but go counter-clockwise. i have had varied success. most common solution was a fresh tool. if you have a good but worn tool with alot of tip on it, cutoff some of the tip with a dremel to get down to a fresh part.
benben10 is offline   Reply With Quote
Old 05-22-2010, 01:27 AM   #4
Guest
Default damn!!!!!!!!!!!
take the car apart and try to turn the piece that it is in, or get drill or drimel?
i feel ur pain boss good luck!!!!!!! i would dremel it first. cause if u drill it, how r u going to get rest of it out of the bulkhead.
LOSIRACER77 is offline   Reply With Quote
Old 05-22-2010, 03:05 AM   #5
Taman's Avatar
Trader Rating: 64 (100%+)
Try Ezi Out - I think that what they are called or go to a machine shop and they should be able to extract it without too much hassel
With the Ezi Out you just drill a small hole in the screw and then screw the ezi out into the hole. Then just remove, we used to use these on strip bolts/ screws all the time.
The suggestion above can work aswell - "take the car apart and try to turn the piece that it is in"
Taman is offline   Reply With Quote
Old 05-22-2010, 05:08 AM   #6
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
any suggestions
Thanks,
kyle
Doesnt look like the only stripped screw there
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 05-22-2010, 05:13 AM   #7
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i have these and work great
http://www.sears.com/shc/s/p_10153_1...2157000P?mv=rr
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-22-2010, 05:21 AM   #8
pakk's Avatar
Trader Rating: 79 (100%+)
I use a Torx bit and tap it in.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 05-22-2010, 07:32 AM   #9
rcko's Avatar
Trader Rating: 15 (100%+)
I just had that happen to me. Here is the fix:
http://www.craftsman.com/shc/s/p_101...2_00952151000P
Only I didnt pay that much for mine. I got mine for $18. I used it on my BMW E30 restoration project with great results.
Same as above post from Smoke. You take that, drill part of the screw head with the drill side of the bit, then reverse the bit on the drill head, put your drill on reverse and drive the special drill bit head into the hole you just drilled on the screw. THe specila bit head will dig into the hole of the screww and back the screw out. It works like magic and no need to dremel a slot and scar your graphite chassis.
BTW,
Looks like you need a better hex bit on your driver. Those other screw heads look pretty bad...
rcko is offline   Reply With Quote
Old 05-22-2010, 10:40 AM   #10
thanks for all the help guys im trying the techniques now
thanks agin,
kyle
Old 05-22-2010, 10:43 AM   #11
timmig's Avatar
Trader Rating: 25 (100%+)
The simplest-- easiest way is the dremel tool cutoff wheel-- if you take your time you can slot the screw without touching the chassis--and simply take it out with a slotted screwdriver. Tried and true method --been doing it for YEARS!!!
FWIW
Tim
timmig is offline   Reply With Quote
Old 05-22-2010, 11:16 AM   #12
try using a piece of paper or tissue and slot it in between the screw and screwdriver
ruein is offline   Reply With Quote
Old 05-22-2010, 08:05 PM   #13
FWIW
Tim
i do this method all the time.... works the best
my other suggestion would be to not put the screws sooo damn tight. just use a lil dab of blue locktight everytime you take one out. this has helped me a tun.... just stop screwing in when the screw stops turning with extremely light pressure the locktight will hold it i promise
onecleanjetta is offline   Reply With Quote
stripped screw in cooling head losi_racer Nitro Off-Road 15 11-26-2008 12:50 AM
stripped screw ntc3freak Nitro On-Road 23 09-21-2004 05:35 AM
Stripped Screw Removal... skibum989 Electric On-Road 23 03-28-2003 02:09 AM
