Old 05-21-2010, 06:47 AM   #1
Norman2's Avatar
Default 1/10 Revolution Pan Car
Hi, I am hoping I can get some advice on a problem I have with my
pan car. I will be running at our local track in Spec Oval. Brushed 21 turn,
NIMH and any tires. The problem is when I give it full throttle it darts to
the left (If looking from the rear). If I only use half throttle or less it will
go straight but when I go to full throttle it will dart left abruptly. I have adjusted the ball diff but still the same. Maybe this is a problem with Oval
cars. Will appreciate any help and advice. Thanks
Norman 2
PS. I will post pictures in the next message
Norman2 is offline   Reply With Quote
Old 05-21-2010, 06:49 AM   #2
Norman2's Avatar
Default 1/10 scale Pan Car Problem
Hi, Attached photos of the pan car I am asking help on the previous thread.
Regards
Norman2
PS I am using BSR Green rear foams and purple fronts,
1/10 Revolution Pan Car-img_0002.jpg
Old 05-21-2010, 08:39 AM   #3
TLRacing's Avatar
You may want to post this on hobbytalk.com. Most of the oval guys are on that form and you will probably get more help. Also post up your setup. What front springs you are running, camber, caster, etc. Also I have attached a setup guide that may help you.
TLRacing is offline   Reply With Quote
Old 05-21-2010, 01:28 PM   #4
Norman2's Avatar
Default 1/10 Pan Car
Hi TL Racing, Thanks a lot for your help. The documents you posted
have all the info I need. Again Thanks
Norman2
Is it time again for 1/10th scale pan cars? outrunner25 Electric On-Road 325 10-21-2012 08:00 AM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 04:55 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
