How fast are you !!!!!!! >
Old 05-11-2004, 05:16 PM
  #31
GundamWZero's Avatar
Yes! I still have that issue too! HPI came out with one that would have done 110+ easily but the car never ran.......bummer. Everything about that car was composite!
GundamWZero is offline
Old 05-11-2004, 05:33 PM
  #32
Tek Nickal's Avatar
They strapped like 30 something cells with Aveox brushless motor. Pritty sick stuff.
Tek Nickal is offline
Old 05-11-2004, 06:07 PM
  #33
Novak Teamed up with Aveox to make the new Brushless motor systems for Novak, However (our little secret) Aveox still makes the RC7, the brushless motor system for touring cars! You can't put the power you want into a Novak than you can a Aveox. Remember, our little secret................
Old 05-11-2004, 06:14 PM
  #34
DaNieL_KuO's Avatar
On my 12th scale Pan car with 6 cells stock motor is already as fast as a 8turn on a 1/10th.At socal raceway once,during practice, I drag raced Josh Numan's mod car down the strait and it was just as fast !With a stock motor!!?! When I put a 10turn on the 12th pancar with 6 cells, DUDE it was the fastest car I've ever driven !!!I almost swear it went like 70 mph +. I remember someones gas car went 72mph clocked on the speed radar, and my pan car is way faster than that ! 12th scale Pancars are STUPID FAST !!!!! or maybe its just me?
BTW I have the L3 [ this car owns !!!!]
What if I put a 6 turn???? maybe with 8 cells!!?!
DaNieL_KuO is offline
Old 05-11-2004, 06:24 PM
  #35
Aveox Brushless systems has no battery limit! And since the motor has no armature, it has no brushes or comms to burn out. Now you are talking a 6 cell system......I'm talking 10 to 12 cell systems!
Old 05-11-2004, 07:09 PM
  #36
Tek Nickal's Avatar
How does it work then? (aveox motor)
Old 05-12-2004, 01:07 AM
  #37
Have you ever taken apart a vaccum cleaner motor? There are no brushes. That is because instead of the wound of the wires being on the armature, it is on the can! The magnet force alone turns the armature, without brushes. Since Aveox primarily dealt with electric aircraft applications, the rpms are extremely high. Some one, a while back, decided to install one in a r/c car. 6 and 7 cells provided ample speed, but had long run times. So, they just kept adding more cells, and the Aveox speed controller handled it. The most I seen on them is 12 cells. I read that there was even more applied, but they melted the diffs or blew tires. With the introduction of the new sub-c cells, you can mount as many as 12 cells and lose the weight, making the car even faster! I wished I had the RC Car Action Mag, or even my Home Computer, but I am in Iraq and there other racers that can back me up on the Aveox systems. Problem is that they are expensive and the come as a set; speed controller and motor. Blow either one, and you're through.
Now I seen Drag cars built on 20 cells and the only thing controlling the power on those things is a switch! Once contact was made with the 20 cells and a 8 turn, single wound motor.......just keep the wheel straight, or you lose the car!
