Keyence Zero Extreme V questions >
Old 05-06-2004, 10:16 AM
FUK_WRX's Avatar
Default Keyence Zero Extreme V questions
Anyone using this speedo with a power cap? I usually run my speedos with power caps but im not so sure about this one?
Hope you guys can help.
FUK_WRX is offline
Old 05-06-2004, 10:24 AM
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Fuk,
It shouldn't/doesn't need any power cap. The only thing i would add is a shotcky (sp?) diode to keep the braking consistent. Its a fantastic ESC, and you should be very pleased with it, especially if you play with the settings.
RCBuddha is offline
Old 05-06-2004, 10:46 AM
FUK_WRX's Avatar
Originally posted by RCBuddha
Fuk,
Seems fantastic actually im starting to like it better than my GM speedo's
You got any good setups for stock?
Or any good setups....
FUK_WRX is offline
Old 05-06-2004, 09:43 PM
RCBuddha's Avatar
Just set everything as to the manual. Adjust the frequency to 1.5 for stock. That should give you lots of punch to start....
RCBuddha is offline
Old 05-07-2004, 11:06 PM
teammediocre's Avatar
I've ran one for about a year now and I will never run anything else.
teammediocre is offline
Old 05-08-2004, 07:44 AM
FUK_WRX's Avatar
its that good??
FUK_WRX is offline
Old 05-08-2004, 09:49 AM
jeepnyy's Avatar
I have been using V Zero Extreme for over a year now. Adrian from SchumacherUSA in Tampa helps a lot whenever you got porblems(sends me a free heatsink, thnx) They are one of the local distributors. I have mine set drive frequency around 2.5 - 5.0 running Arcor super spec 4 cell high-bank oval at BMS. Never give any problem at all.
jeepnyy is offline
Old 05-08-2004, 06:22 PM
I have been runing one for a while now and find it pretty good but i seem to have HEAPS more runtime in my packs after a race compared to any other .. running oval you would see this better... do you find the same thing???
Dragonfire is offline
Old 05-08-2004, 07:03 PM
littledog's Avatar
I got mine from friend in need a few weeks ago.I'll be using for the fist time at my next venue.I'm stil a little scared about programing it.At least I have instructions to read..............Now if it only had more pictures in the instruction booklette,than words
littledog is offline
Old 05-08-2004, 07:35 PM
eeyan's Avatar
Enjoy your speedo littledog... I've had mine since late 2000 and both have not failed me for almost 4 yrs now ***knock on wood*** (I got two of the special edition black versions; looks cool too with the special holographic top plate!)
eeyan is offline
Old 05-08-2004, 07:47 PM
TFR
TFR's Avatar
Do you have a picture of that special edition ESC of yours?
TFR is offline
Old 05-08-2004, 09:23 PM
Any idea on where to buy these speedies cheap?? I am looking for another one soon and don't want to buy it from the uk again....
Old 05-08-2004, 09:31 PM
Schumacher is the only one I know of and speed tech.You knoww it's a keeper when it tells you HELLO when it comes on
Old 05-08-2004, 10:02 PM
jeepnyy's Avatar
With my set-up on lower drive frq...i noticed that my comm stay shinny not burnt/brown. my motor is not as hot and my batts have about 10-15 secs more time left in them. Adrian from Schumacher have mention the 2002 ver is being replaced. Call him for up to date info. I would wait for the new speedo if i were you.
jeepnyy is offline
Old 05-08-2004, 10:04 PM
kewl.... thats in USD i presume... thats heaps cheaper than the shumacher (spelling?) website.
