TCR wheel Nut driver for XXX S >
Old 05-05-2004, 09:37 PM
Default TCR wheel Nut driver for XXX S
I have been looking all over for a nut driver to fit inside of the TRC wheel well for the Losi XXX S. Does anyone know who makes it?
Also
I'm looking for a set of set up wheels that fit on the Losi XXX S shaft?
datruth99 is offline
Old 05-06-2004, 05:05 AM
lastplace's Avatar
I took a 11/32 socket and ground down the edge so it would fit.
lastplace is offline
Old 05-06-2004, 08:44 AM
RandyB's Avatar
Yokomo makes one that I am pretty sure fits
RandyB is offline
Old 05-06-2004, 08:53 AM
clinttredway's Avatar
Default Re: TCR wheel Nut driver for XXX S
Also
The Losi nut driver fits.. that's what I use..
clinttredway is offline
Old 05-06-2004, 10:20 AM
Trinity makes a nut driver that fits it is 11/32 the ground down socket will work as well and is cheaper if you have a nut driver already
Javen13 is offline
Old 05-06-2004, 07:42 PM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Adding to the mix, Hudy's works awesome as well.
Randy Caster is offline
Old 05-07-2004, 06:38 AM
RcMonk's Avatar
I picked up a Craftsman nut driver(one of those stubby ones) from Sears when I first got the Losi car. Heck I even brought the TRC foam tire with me to Sears. Now I use Losi nut drives.
RcMonk is offline
Old 05-07-2004, 07:17 AM
Default Set Up wheels
Thanks for your help guys.
Anyone know of a pair of set-up wheels that will fit on the XXX-s shaft?
Old 05-07-2004, 08:27 AM
Losi made some setup wheels a while ago, I dont know if they are still avalible or what though...
