R/C Car Handling Characteristics >
Old 05-05-2004, 01:12 PM
  #16
This is the handling guide I downloaded for TC descriptions ofwhat each thing does.
http://home.tiscali.be/be067749/58/
SRW141 is offline
Old 05-05-2004, 01:24 PM
  #17
lower roll centre e.g higher longer camber links or lower wishbone blocks gives more body roll more grip less stabillity.
higher roll centre gives opposite.
same as softer springs give more traction less stabillity and more body roll.
also a car with a high c of g or ride height will give increase of grip but rolls moe thus losing stabillity.
on low grip tracks try higher ride height,lower roll center,softer springs etc.
trf racer is offline
Old 05-05-2004, 01:41 PM
  #18
One of the basic rules is that a lower CG will generate more cornering grip. Transfering more grip to the outside wheel will not give more cornering grip. A higher CG will give more traction when accelerating in a stright line like in dragracing.
AtheenaProjects is offline
Old 05-06-2004, 02:33 AM
  #19
sorry,i dont think i expained very well.
when i say increase ride height i mean like 2mm at the most.
this will transfer more weight to the outside tyre but not enough for it to sleep side ways.
Old 05-06-2004, 02:43 AM
  #20
Thanks everyone for the feedback
If the camber links are parallel to the suspension arm, I think this will result in a low roll center, right?
So if I angle the camber links to point down, roll center will be higher. Am I right or I got everything wrong
EUracer is offline
Old 05-06-2004, 02:47 AM
  #21
that is correct the more they point up the higher the roll centre the more they point down the lower the roll center.
if they are parelel with the wishbones its a low roll center as well.
Old 05-06-2004, 02:52 AM
  #22
Thanks trf racer for your help.
Just one question. When you say pointing up (for high roll center), looking at the car from the driver's seat, say left back wheel, which part of the camber link has to point up?
EUracer is offline
Old 05-06-2004, 02:55 AM
  #23
there is nothing basic when you talk about center of gravity,roll center,or ride height.
its just got to be a just write.not to much grip but enough and the same with stability.
i think you are confused about grip and stabillity.
stabillity is when cornering how flat the car is.
you can have a flat car going into and through a corner but it may have no grip.vice versa you may have a car the grip rolls but it has no stabillity.
so you got to have a balance bt stabillity and grip.
on ashphelt you normally go towards producing more gip ie softer springs lower roll center etc but on carpet youd want more stabillity then grip so youd stiffen springs and go for a higher roll center.
also remember car width makes a difference.
a wider car would have more stabillity but may lose grip.
a less wider car will have the opposite,more grip but less stabillity.
hope this clears things up better.
Old 05-06-2004, 02:57 AM
  #24
sorry,i meant that if you ant a high roll center the outer part of the link should be higher compared to the inner part of the link.from were ever you look.
Old 05-06-2004, 03:00 AM
  #25
EUracer is offline
Old 05-06-2004, 03:04 AM
  #26
that would give a higher roll center then compared to if the top link was parralel to the wishbone.
Old 05-06-2004, 03:06 AM
  #27
So for example as in the photo above, if I make the upper link parallel to the bottom link, thus lowering the outer link roll center will decrease
EUracer is offline
Old 05-06-2004, 03:07 AM
  #28
At last, I think I understood
EUracer is offline
Old 05-06-2004, 03:11 AM
  #29
yes that is correct.you could also lower the inner pivet of the wishbone to get the same effect.
Old 05-06-2004, 10:37 AM
  #30
trf racer
According to an article in Race tech magazine overall load transfer depends only on CG heigth and the width of the car's track. Dampers, springs and geometry only controls how the load transfer varies from front to rear and also how it varies as the car passes through the entry, apex and exit of the corner.
It also states that load transfer is bad for grip.
