novak brushless bearing size ? >
Old 05-05-2004, 01:50 AM
Default novak brushless bearing size ?
Hi,
what's the size of the novak brushless motor bearing ?
I email novak on where to get the replacement but
no reply. Planning to get from others. please advise.
ongbenghui is offline
Old 05-05-2004, 02:02 AM
fatdoggy's Avatar
Just measure it. Diameter outside, diameter inside and width. Not sure if it's in that order.
fatdoggy is offline
Old 05-05-2004, 08:34 AM
You're right Fatdoggy. It's inside, outside and width.
Standard pinions fit the brushless motors shaft so I assume that they used the same size bearing as brushed motor. At least the inside diameter is the same.
andsetinn is offline
Old 05-05-2004, 12:00 PM
The bearing im not sure on the side only that it is Novak part #5900 hope this helps
Javen13 is offline
