Modified Motor Forum _+_+_+_+ >
Old 05-04-2004, 05:22 PM
Trader Rating: 42 (100%+)
Default Modified Motor Forum _+_+_+_+
Just thought I'd start a thread to see what modifieds people are running....
Looking for opinions on the new 4mag KR's and D6 mods....or...by chance have alot of people had a chance to run the new Orion Revolution mods....looks like Hara and some other guys threw down pretty good at the Pre-Worlds.
Nexus is offline
Old 05-04-2004, 06:41 PM
=MisFitz= NuKe's Avatar
well, I am running Redline stuff. EJ doesnt have a website up YET, but he is very well known through out Cali. I used to run the Kr's, and they were very fast too, and I tried the D5, flatwire, and that was the biggest piece. Some guys are running the Orion Revs. at our track, and they are also very quick.
=MisFitz= NuKe is offline
Old 05-04-2004, 08:09 PM
my D5 haulzzzzzzz
R/C Anonymous is offline
Old 05-04-2004, 08:19 PM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
All the D5's I've seen have been really good... I prefer the D6 right now, but I am testing with Kr's to see if that's gonna be the motor to run.
Randy Caster is offline
Old 05-04-2004, 08:48 PM
black-knight's Avatar
What about Revolution Orion/Peak motors have these been ontrack in the US much (at Club level) ?
black-knight is offline
Old 05-04-2004, 08:53 PM
I tried the revolution motors but they are really too smooth for me, I like a regular endbell motor personally. One nice thing about the revolution endbell is that the brushes definately do last forever. I'll use brushes for 1 run in my D6's or Kr's but was able to go 3-4 runs with a revoltion before the power sucked.
Old 05-04-2004, 09:17 PM
My D5 11x1 brushes lasted me about 3 packs before the tips turned purple...yes the tip turned purple
I like mod, I can't afford a new motor (I want one)
I'm getting some hodge-podge mod within the next week (week is a long time) "old 12x2 can with a 10x2 Arm...probably needs a rebuild" - can't beat the price of free. Maybe I'll pop the 10x2 arm into the D5's can.....
I'm bored....I just needed to write something along the topic
The Black Kat is offline
Old 05-05-2004, 04:54 AM
pro4_chris's Avatar
the revolution motors are great i took 3 seconds off my time by switching form a orion core 12x1 to a hara 12x1 and the brushes last much longer, even more so if you use the enduro brushes
pro4_chris is offline
Old 05-05-2004, 08:59 AM
Wency_TA03R-PRO's Avatar
Exclamation
KR and PT then TI reedy motors are great modified motors. But if you want to go faster and have a budget for a modified one why don't you try the hand-wound motord.. Im sure you'll be satisfied for what you pay for.. Anyway its just a suggestion..
Wency_TA03R-PRO is offline
Old 05-05-2004, 11:02 AM
rtypec's Avatar
umm wency, most of the motors mentioned already ARE hand-wound motors, and are plenty fast. Atleast fast enough to get into trouble...
rtypec is offline
Old 05-05-2004, 11:44 AM
ive used the peak surikrn edition 12*1 HS and the reedy KR 12*2 HS and the peak had much more bottom end torque but the KR had a bit more top end.
but overall the peak is by far the best.
trf racer is offline
Old 05-05-2004, 02:04 PM
Exclamation
yup! they really are a fast motors.. So this means getting your kit that fast depends on how you drive it away from the solid walls or else you just slam it really bad..
H A P P Y R A C I N G!!!!!!!!!
Old 05-05-2004, 02:12 PM
using a 9T KR or D6...
what type of rollout (measured in inches) would you be running at a large 185ftx100ft track?
Nexus is offline
Old 05-05-2004, 02:28 PM
tufferwilde's Avatar
As far as the orion/peak V2 motors... you really con't go wrong with them, possibly the only spot they are lacking is some of the bottom end grunt for TC... Off road, they are by far the best motors I have run in a long time.
Not to mention the time between rebuilds! 30 runs on 2WD mod, 15 on 4WD
Wilde
tufferwilde is offline
Old 05-05-2004, 03:37 PM
Rowdy's Avatar
I ran an orion V2 for the first time last weekend. It was a blue endbell modified version 8x1. I found it to have plenty of power down low but I thought it lacked some top end speed. The motor was very smooth and efficient, I was coming in with about 30 seconds more runtime than with a core touring.
I read this week on the orion website that an 8x1 modified version is equal in power to a 10x1 touring version, so that may explain the increase in runtime. I thought 30 secs was a bit to good to be true.
Rowdy is offline
