TC3 Spur Gear Selection 48 pitch >
Old 05-04-2004, 06:05 AM
Tech Legend
Cain's Avatar
Trader Rating: 287 (100%+)
Default TC3 Spur Gear Selection 48 pitch
Just a quick question.
Is it possible to run a smaller spur gear on the TC3 like a 69 tooth ?
I pretty much will use pinion gears from 26 to 30 tooth.
Thanks!
Cain is offline
Old 05-04-2004, 06:33 AM
Robinson racing sells gears made for the tc3 in 48 pitch:
70,72,74,76,78,80
they are very light and durable, I have been using them for a while.
http://www.robinsonracing.com/catalo...pur.html#ultra
MManson is offline
Old 05-04-2004, 07:39 AM
Wency_TA03R-PRO's Avatar
Exclamation
70,72,74,76,78,80
cool link bro!!! I'll try it nxt week.
Wency_TA03R-PRO is offline
Old 05-04-2004, 08:10 AM
Tech Legend
Cain's Avatar
Thanks, just trying to see what would be more cost effective as I can either switch the spur or buy another pinion.
Cain is offline
Old 05-04-2004, 10:09 AM
I use 69 for 19 turn motors and 75 for stock motors.
Steve
SRW141 is offline
Old 05-04-2004, 10:26 AM
V12
V12's Avatar
Xenon makes spurs 65,66,67...... 89 teeth 48DP
so there are different choices for the TC3. Yokomo SD and HPI Pro4 spurs are the same.
When I was running the TC3 I think I was using a 67 teeth spur with stock motors at some large tracks.
V12 is offline
Old 05-04-2004, 10:59 AM
Tech Legend
Cain's Avatar
Great, I think I may make a stop the LHS and see what they got for gear selection.
Cain is offline
Old 05-04-2004, 11:14 AM
Tech Legend
Cain's Avatar
LHS only carries a large selection for pinion sizes up to 50 tooth, so I am going to get a larger pinion ( just 1 ) and go from there.
Where can I order these spurs cheap?
Cain is offline
Old 05-04-2004, 11:24 AM
V12
V12's Avatar
Speedtech sells them as Speed Tech R/C Light Weight Precision Spur Gears.
I tried lot of spurs in the past and the Xenon are some of the best available.
V12 is offline
