check out this new tc3 conversion kit
thread is no longer informative pleae go here for questions about the new kit thanks
http://www.rctech.net/forum/showthre...threadid=39959
futureal if u can delete this thread thanks i have created the new on in the link..
no Brian the motor mount is COMPLETELY different looking
one more slot, more cutouts on the bottom chassis under the tranny cases, and a reworked upper deck...along with the turnbuckle adjustable rear toe-in like a Schuie, and off centered battery brace. You should see the one i helped dream up...if only i had the ok to show the pics
the motor mount on the kit i have is one from a demon .... my machinist has not gotten our motor mounts done yet.. so for testing i used whatever one i could find.....
if u look at the actuall chasis it does not look like a demon... the edges are different (wider for more stiffness) as far as the battery slots, and motor cutout... u can only do so much to make them different on a chassis kit.... the toplate is different to...
new pics below .. minus parts to cause controversial look alike comments... thanks
