Old 05-10-2010, 02:17 PM   #1
Default 24mm tire on 26mm rim??
is it ok?
TL01 W/5.5T Brushless
JAMMIN X2 TRUGGY W/Force .28
wantboost is offline   Reply With Quote
Old 05-10-2010, 04:55 PM   #2
Trader Rating: 24 (100%+)
Originally Posted by wantboost View Post
is it ok?
Uh...no...but why would you want to ??
Evoracer is offline   Reply With Quote
Old 05-10-2010, 05:00 PM   #3
was reading this http://forums.radiocontrolzone.com/s...d.php?t=167826 they say its ok.
I have 26mm rims and i ordered 24mm by accident.
Old 05-10-2010, 05:21 PM   #4
I can almost understand the points they make but...remember also that it's a tuning possibility thats way out on the fringe....it may make tuning your car a bit tougher. Also be aware that if a car goes through tech at a race and it gets noticed, they may have a problem with it. Never tried it myself.
Old 05-10-2010, 05:23 PM   #5
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
is it ok?
Yes you can do this. Way back before there was premounted/spec tires this was a tuning aid when building your own tires to race. Some tires worked better on 26mm rims then on 24mm.....so Yes you can do this. It will make the tire lower profile as well.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 05-10-2010, 05:40 PM   #6
whoopass's Avatar
in the UK 2-3 years ago we always used 26mm rims and inch-ups with 24 mm tyres with great results. the tyres don't roll on themselves anywhere like they do on 24mm rims. also in hot conditions they are much more consistent as the tyre does not move as much on the rim generating less heat.
We also used to glue 21mm pit wets on 24mm rims with great success in results in the damp/wet.
run the 26mm, they are great!
whoopass is offline   Reply With Quote
Old 05-10-2010, 10:26 PM   #7
Born2Run's Avatar
What inserts on 26mm rims? For 24mm or for 26mm?
Whatever
Born2Run is offline   Reply With Quote
Old 05-10-2010, 10:38 PM   #8
whoopass's Avatar
we used to use Schumacher magenta or yellow, or HPI yellow. felt really nice
Old 05-11-2010, 04:44 AM   #9
good question!! i assume 24mm inserts???
Old 05-11-2010, 05:48 AM   #10
whoopass's Avatar
yes standatd 24mm inserts work fine, as you are stretching the tire slightly, they fit fine.
Old 05-11-2010, 09:30 PM   #11
PaPeRo's Avatar
I would think you'd get less traction rolling too when using 24/26.
deans - dodgy electrics amps not sufficient
PaPeRo is offline   Reply With Quote
Old 05-12-2010, 01:20 AM   #12
whoopass's Avatar
as the tyres are 26mm wide you get slightly more traction as 2mm more tyre is in contact with the track. let us know your thoughts after running them. As all tyres now used in competition are pre-glued controlled tyre, i think some of the fine tuning has now been lost, where you could be a 10th or 2 quicker due to tyre setup, but thats all gone unfortunatley.
Old 05-12-2010, 04:31 AM   #13
i just using for bashing. I wanted to get the HPI Advan A038 Belted Tire, 24mm, 33R HPI4763 since i assume they would be better than the 26mm xpattern ???
Old 05-12-2010, 05:06 AM   #14
whoopass's Avatar
I run TC and have no idea what you just said.LOL
Old 05-12-2010, 01:27 PM   #15
I am just using my car for bashing so what tire would be better? HPI xpattern belted 26mm or HPI advan a038 33R 24mm? Also, does the 2mm make a difference?
Grande Prairie Summer On-Road T493 Canadian R/C Scene 436 09-27-2009 09:37 AM
Rubber Tire touring car racing... Nexus Electric On-Road 183 06-18-2006 08:41 PM
