Old 05-10-2010, 02:11 AM   #1
monkee's Avatar
Trader Rating: 15 (100%+)
Default velcro battery straps
do they work that good? or what do you guys use..
as you will see in my bottom pic, i had used a large ziptie to strap my battery down tight. at least i thought it was tight.
until today when i was ripping it around a corner and the battery slid out.. and pulled out my receiver cables and ripped the receiver right off its base.
im lucky that the receiver was able to be put back together and still works..
the velcro or w/e i will use to tie the battery down has to be long enough to run under the chassis and back up and strap down super tight.
monkee is offline   Reply With Quote
Old 05-10-2010, 03:47 AM   #2
FREAKAH's Avatar
Velcro strapping would still allow the battery to slide out. Just use stick-on weights that are shaped like the battery slots in your chassis on the underside of the battery to locate it and keep it from sliding.
http://www.hudy.net/xhudy/news/newsd...da856b13a8a3e5
Or if you do not want to add weights since your'e using a nimh pack, cut out some thick plastic(like Kydex) to fit in the slots and stick them to your battery pack.
As far as strapping the battery pack in, just use strapping tape. You may need to use two thinner straps just so you can clear the battery wires coming out from the end of the pack. If you're concerned about looks, look for the r/c specific black or blue battery tape. Don't forget to fold the overlapping ends over so it will make it easier to unstrap.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-10-2010, 06:22 AM   #3
FOXY923's Avatar
This has nothing to do with the battery strap, just about your plugs. Are those real deans? If so check the polarity on the plug. I think you have the +- reversed. This won't be a problem if your only using your equipment for now. But if you end up at a track and need to borrow a battery pack your going to fry something. Also, most good packs are now coming with deans attached, ie Orion Rocket pack lipos, these will have the plugs on the right way and will fry your electronics as soon as you plug it in.
Check those and make sure they are the right way. | - <---is the plug, the | is the + and the - is the -.
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 05-10-2010, 10:33 AM   #4
monkee's Avatar
yes they are real deans.
everything i have is wired backwards
ive never taken the time to unsolder everything and resolder it all
i like the plastic idea.. ill figure something like that out.
Old 05-10-2010, 10:50 AM   #5
Geezatec's Avatar
Velcro on pack will come loose. Useing velcro strap will work fine, airplane guy use. Epoxy it on chassis. Don't use hot glue, cuz charging the pack, in chassis will heat up and pack will come loose. and relocate pack on chassis.
Look into lipo packs. Lighter then NiMh, you can use strapping tape to use. Most new type chassis Strapping tape is used. Lipo has better punch!! on Brushless systems.
Geezatec is offline   Reply With Quote
Old 05-10-2010, 11:06 AM   #6
FOXY923's Avatar
As long as you know.
RACE 4FUN
Old 05-10-2010, 01:10 PM   #7
some 1mm or thicker chassis protector tape also works great to attach to batteries and key them into the slots like freakah mentioned
benben10 is offline   Reply With Quote
Old 05-10-2010, 03:17 PM   #8
monkee's Avatar
if i switch to lipo...
those batteries are light enough that just regular electrical tape would hold that battery in place??
Old 05-10-2010, 03:27 PM   #9
Geezatec's Avatar
Can use electrical tape. Other are useing thread tape, for they come it differant colors. Like Clear, Blue, and black.
Old 05-10-2010, 04:00 PM   #10
monkee's Avatar
lipos weigh a lot less than nimh packs i take it
Old 05-10-2010, 11:30 PM   #11
Geezatec's Avatar
Yep!
Old 05-11-2010, 04:19 AM   #12
tc3team's Avatar
maybe you are looking for something like this?
http://www.rcmart.com/catalog/batter...-c-52_955.html
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 05-11-2010, 08:41 AM   #13
monkee's Avatar
i originally bought that exact 3racing strap for this project car.
but i never used it for 2 reasons..
first you have to drill thru the cf to install it. which i didnt really care to do
and secondly, with the posistioning of the upper cf deck and the receiver in front, there wasnt enough room to get it installed.
xxx-t battery strap conflict w/ my new lipo bigbadyoda Electric Off-Road 12 01-29-2009 04:52 PM
Velcro Battery Strap?? Anyone make one? cpatel529 Electric On-Road 16 07-06-2007 06:15 PM
Speedmind Battery Straps walkercart Electric On-Road 8 04-16-2003 10:38 PM
