Old 05-08-2010, 02:50 AM   #1
merschc's Avatar
Default tamiya tt01d engines
ey what is the fastest engine that fits into the tt01d??
merschc is offline   Reply With Quote
Old 05-08-2010, 03:21 AM   #2
Foxxrocket's Avatar
You might want to look in the onroad nitro forum.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 05-08-2010, 03:36 AM   #3
Why ?? i TT01 is electro
D is for Drift
i am guessing you are a beginner so start with low power like 17.5 brushless and work from there
drifting is not about power and too much can destroy your fun
sidecarphil1 is offline   Reply With Quote
Old 05-08-2010, 03:49 AM   #4
Foxxrocket's Avatar
Is it? I don't know. He said engine, so I thought he was in the wrong forum.
Old 05-08-2010, 03:54 AM   #5
yeah i read that bit now too
i think he wants to know what motor is best fr a TT01
Old 05-08-2010, 07:29 PM   #6
fastest motor: how much $$$ have you got?
You will get into problems on the 1st corner
TT01d is NOT designed for high power motors.
Limited on pinions & spurs you can use because of the crazy motor mount: its designed for beginners. You may not be able to get the gearing you need to suit the motor.
Also, standard pinion is too soft. You will need a hardened pinion.
Ezrun 9T will fit easily. Quite fast in a 'normal' 1/10 car.
9T Ezrun is a good motor for drifting as well.
1101 is offline   Reply With Quote
Old 05-10-2010, 05:39 PM   #7
monkee's Avatar
Trader Rating: 15 (100%+)
i like drifting with a checkpoint 19t money motor
monkee is offline   Reply With Quote
Tags
tamiya tt01d racing car
