Speed Passion Cirtix Stock CLUB ESC >
Old 05-10-2010, 08:20 AM
  #61
Originally Posted by 2wdrive View Post
those cirtix enspire2.0 were not abused. When the first few burned up the drivers used the fdr that the distributor told them to use and they still burned after that. It is not only one that it happend to but quite a lot. Even with very experienced drivers the esc burned when used with a mild fdr.
Not that it matters as they are using the stock club now (they changed it from enspire to stock club) but those enspire's were just not up to the job with the 3000kv sensorless motors. (or it had to be a very bad batch)
Yesterday another one burned down...The one who was driving was a well experienced international driver. He thought he would break his dad's personal record with his car. He did, but ended up smoking the ESC...
Govert is offline
Old 05-13-2010, 07:50 AM
  #62
M-Technic's Avatar
Trader Rating: 15 (100%+)
Got a chance to drive the Cirtix motor (17.5) and speedo combo last night. It is surprisingly fast. Easy to setup, geared it at 3.5, and it was very quick in an RCGT car. We could never get it over 105*F.
I think this setup is a winner.
M-Technic is offline
Old 05-13-2010, 07:58 AM
  #63
Jochim_18's Avatar
I'm still waiting for mine to test hopefully it will be here today or tomorrow.
Jochim_18 is offline
Old 05-13-2010, 11:03 AM
  #64
Trader Rating: 26 (100%+)
M-Technic - Were you running indoor or outdoor? Fan? Surface? Outside temp?
svines1972 is offline
Old 05-13-2010, 11:15 AM
  #65
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by rocketron View Post
This should be a great ESC for all the new 21.5T Stock SPEC classes. It is also on the ROAR list of Non-timing ESC's
I have to update my comment - Speed Passion has since updated ROAR with the fact it is a timing built in ESC and not a Stock Spec ESC (no timing)
Speed Passion is currently in process of getting a non-timing esc to market.
rocketron is offline
Old 05-13-2010, 02:52 PM
  #66
fat500's Avatar
Trader Rating: 32 (100%+)
m-tech races at my local track. it is a smooth outdoor raceway. about 83 deg outside. I will be installing this setup in my tb03 for our new spec class and i will report back here.
I have heard nothing but great things from the local racers here. This combo will re-ignite rcgt
the ones that were buring up were not SSpec combos
these babys do not even get hot
fat500 is offline
Old 05-13-2010, 02:58 PM
  #67
Jochim_18's Avatar
Good to hear everyone is having a good results with this Speedo/Motor my wife just informed me that I got a box waiting for me at home.
Old 05-13-2010, 03:16 PM
  #68
Super Moderator
charlie_b's Avatar
In Both indoor carpet and outdoor asphalt, this system runs very cool. I am curiuos how hot or how Cool it will run in our Cali Summer days outdoors.
charlie_b is offline
Old 05-13-2010, 03:17 PM
  #69
Super Moderator
charlie_b's Avatar
Opps
Old 05-13-2010, 07:24 PM
  #70
M-Technic's Avatar
Like fat500 said - it's outdoor and a fairly large asphalt track. It was hot and humid, I'd say low to mid 80's and 80% humidity. Most runs the motor was below 100*. The stock fan was on the speedo but if the motor was 100* I can tell you it wasn't stressing the speedo at all. Car had good rip and wound out well. It might be able to take more gear than the 3.5 we had it geared at.
Old 05-13-2010, 07:48 PM
  #71
Ericjooopuntnl's Avatar
Govert,
You're talking about a Cirtix sensorless with 26,5 degrees of timing. As far as i know the ETS-Cirtix will be a sensored low timing ESC. When you do 3.5 on the MACH-Cirtix it will burn; the ETS-Cirtix can really handle the 3.5 in tests they went down to 2.5 without burning!!
greetz,
Eric
Ericjooopuntnl is offline
Old 05-14-2010, 01:50 AM
  #72
Robert_K's Avatar
Originally Posted by Ericjooopuntnl View Post
Govert,
greetz,
Eric
We even went down to 1.9, but then the motor got a bit hot
Can't wait till next weekend
Best Regards
Robert
Robert_K is offline
Old 05-14-2010, 03:06 AM
  #73
Best Regards
Robert
WTF 1.9 that is a 50 tooth spur with a 50 tooth pinion on my T3 !!?
I am struggling to get to 3.5 with my car !!!
sidecarphil1 is offline
Old 05-14-2010, 08:26 AM
  #74
Jochim_18's Avatar
I got my Cirtix/17.5T Combo yesterday. I will be racing this weekend in a fairly small track I would say 90x40... What's the starting FDR you guys are suggesting? This will be a test run for our club and see how Cirtix Stock Club ESC performs I will be racing it against Timing Advance ESC it will be fun if I can keep up with them
It's pretty cool the motor looks like silver can but it's brushless.
Old 05-14-2010, 08:32 AM
  #75
Super Moderator
charlie_b's Avatar
Start with a 3.7 then go up or down from there. Have fun!
