Old 06-28-2011, 10:32 AM   #706
HoJo's Avatar
Default Reverse
Using SP Cirtix Stock club esc for off road. Was wondering if this esc has a reverse function. I have not been able to figure this out, even after reading the esc manual.
Thanks in advance.
HoJo is offline   Reply With Quote
Old 06-28-2011, 11:45 PM   #707
Urabus23's Avatar
Thanks in advance.
I think the Club Race esc's are brake only.
Tamiya TB-03 : Speed Passion Club Race 17.5 : Airtronics MX-Sport
Urabus23 is offline   Reply With Quote
Old 06-29-2011, 12:56 AM   #708
HoJo's Avatar
I see. Thanks for clarifying.
Old 07-01-2011, 02:41 PM   #709
koval's Avatar
Default CIRTIX STOCK CLUB PROBLEM
i bought this esc used from ebay but i have a problem!
i read carefuly the instr manual so to calibrate with the motor(sp competition 3)!
but after calibrating red led is blinking(manual says that red led bliking when detects low voltage)and nothing work exept fan !i tested several times with other 2s battery that was fully charged even test the motor with other esc and it runs great!that means that motor and batterys are ok !i even checked with other transmitter but after many hours calibrating many times and testing still the same thing!what can cause this problem??the esc seems to be new and seller said that he just calibrate that to see if it is ok and didnt even run it in his car!
any opion will be helpful!!!
THANKS!!
koval is offline   Reply With Quote
Old 07-01-2011, 02:47 PM   #710
Trader Rating: 69 (100%+)
THANKS!!
Which radio are you using? Try to reverse the throttle and then recalibrate again. For my KO PROPO radio, the ESC only work with reversed throttle.
eComet is offline   Reply With Quote
Old 07-01-2011, 02:53 PM   #711
koval's Avatar
I DID THAT !!STILL THE SAME
Old 07-01-2011, 02:57 PM   #712
After calibration you need to turn the speedo off and on agan , then wait like 5 seconds for it to boot up
If you have speedo with the wire that can unplug from the speedo the flashing light is for the ROAR rules only
try waiting before giving throttle and see if it works then , if not them maybe you have a faulty item
sidecarphil1 is offline   Reply With Quote
Old 07-01-2011, 02:57 PM   #713
koval's Avatar
I TRIED WITH SEVERAL TRANSMITTER LIKE ACOMS SANWA HOOBYKING KYOSHO!
Old 07-01-2011, 03:25 PM   #714
I don't think the Cirtix ESC has blinking red LED because it's non-updatable.
I had a faulty Cirtix Short Course Master before, and I just couldn't get it to calibrate at all, i.e., the calibration button is faulty.
Try to PM Solara and see if he can help you out! He works for Speed Passion.
Old 07-02-2011, 12:06 AM   #715
koval's Avatar
sidecarphil1 i have done this a lot of time ,unfortunately nothing!
eComet thank you ,i ll contact with and hope to give some good advise!
Old 07-10-2011, 03:55 PM   #716
Hi,
what sort of fdr do I need using a SP 13.5t V3 indoors with a 35m straight quite technical and outdoors with a 45m straight pretty open and flowing and do most people leave the SP timing on the motor in the middle ?
Thankyou.
S.A.W is offline   Reply With Quote
Old 07-11-2011, 10:09 AM   #717
Trader Rating: 16 (100%+)
Originally Posted by S.A.W View Post
Hi,
Thankyou.
No, turn the timing ring to full right 10.....and gear around 4.5.
Old 07-11-2011, 10:12 AM   #718
THANKS!!
Does that work without the sensor wire.......calibrate the ESC without the sensor wire and see it run in sensorless mode. If that work with sensorless mode...your ESC sensor harness is faulty.
Old 07-11-2011, 12:14 PM   #719
Thanks, is that for indoors ? what about outdoors.
Old 07-11-2011, 12:17 PM   #720
Don't matter...I never run the V3 in the middle or full left, always at 10.
If you are running on bigger track outdoor...gear up. still, start from 4.5 and work UP and check motor temp every 3-5 laps.
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
Real Stock On Road Racing... Me_MrTyson Australian Racing 214 05-19-2010 06:06 AM
