Old 04-15-2011, 09:38 AM   #661
Originally Posted by Solara View Post
Setup with reverse first....if not working, reverse the throttle.
ABS braking, default is 50%.
You can try 40% drag braking....club spec required higher % in drag braking compare to other SP higher end ESC.
Does drag brake default to 40%?
Can you point me to programming step menu different than the one I donwloaded from speedpasison site, it does not really show anythign about setting drag and ABS braking or maybe I am missing it?
RCveteran is offline   Reply With Quote
Old 04-15-2011, 10:42 AM   #662
Trader Rating: 16 (100%+)
Acutally, I am not sure it is setup @ 40% or lower...I usually don't care, I drive the car first and adjust MORE or LESS of what I had....
There are no step manual...plug in the programmer box and you should see only 3 adjustment area. See below link, 3rd image from the left will show you those area that you can adjust, this decal should came with the programmer that you ordered.
http://www.speedpassion.net/us/produ...PESCPB01&c=OPT
Old 04-15-2011, 10:46 AM   #663
Ahhh, I do not have a progammer box. Was it supposed to come with it? If not, can I run without it, hoping to run a VTA race this Tuesday
Old 04-15-2011, 11:39 AM   #664
No, it does not, it is an optional item.
Yes, you can run without the box, you just cannot adjust the ESC setting without the box....see you can borrow one or buy one, you will need it for VTA for better brake adjustment.
Old 04-15-2011, 11:47 AM   #665
Thanks, I will get one just won;t have time before Tuesday. So basically for now, I should just calibrate my throttle and that will get me going at least.
Old 04-15-2011, 11:49 AM   #666
Yes it will run...and for USVTA, you won't be much different then others with the box...it is only brakes adjustment, the speed of the VTA are all the same.
Old 04-16-2011, 04:27 PM   #667
V12
V12's Avatar
Actually you need the programer just for adjusting drake brake.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 04-18-2011, 07:41 PM   #668
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Default program box
Get it from TQ racing it's the cheapest place I found,and they are great to work with.
JG
jgraham37128 is offline   Reply With Quote
Old 04-18-2011, 09:18 PM   #669
hanzo3's Avatar
Trader Rating: 55 (100%+)
I have the v1 cirtix esc. Does anyone know if the Duo 3 works with it? I bought a novak ballistic and stupid me it doesn't work. Shame on SP
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 04-18-2011, 09:48 PM   #670
trackrat3
Guest
Posts: n/a
I turn my drag brake all the way down for VTA. Much better for carrying corner speed.
Old 04-19-2011, 06:20 AM   #671
Default v1
I have a Speed Passion Citrix and a 25.5 Novak Ballastic and no problems. I don't know if mine is a V1 though.
Old 04-19-2011, 01:30 PM   #672
hanzo3's Avatar
I have the first version and a novak 17.5 didn't work. You must have the newer version. Duo 3 anyone"?
Chris TRF419 TA05V2
Old 04-20-2011, 12:36 PM   #673
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Question:
Currently using the Citrix Stock CLUB ESC with a 21.5 in an F1 chassis. Will this ESC also power a brushed motor (Silver Can)?
Thanks in advance
madjack is offline   Reply With Quote
Old 04-20-2011, 03:28 PM   #674
I was getting ready to order the short course 17.5 master # 11021 combo off of the speed passion website for and was wondering how long it takes to get it?
Also why is the shipping so high? When I put it in my cart, it only gives option to air ship and is $30 to ship.
robzzz is offline   Reply With Quote
Old 04-21-2011, 10:41 AM   #675
madjack's Avatar
Anyone.... Bueller....
Question:
Thanks in advance
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
Real Stock On Road Racing... Me_MrTyson Australian Racing 214 05-19-2010 06:06 AM
