Old 11-26-2010, 08:59 AM   #556
V12
V12's Avatar
Canīt say if the Cirtix works with 1S and the booster but at least works for a lot of guys here using 2S and different motors. I donīt think the ESC could burn up if the sensor wires fail, actually the Cirtix should switch to sensorless mode in this case.
One thing I noticed when running Corally or Graupner (outlaw) type motors, when running on low throttle there is a very strange noise coming from the motor. Sounds like a broken drivetrain.
V12 is offline   Reply With Quote
Old 11-26-2010, 02:29 PM   #557
soloistrc's Avatar
Originally Posted by g12314 View Post
That TA05 pictured is actually my car. Unfortunately, I have it disassembled so I cannot get you a close-up picture. What question about the wiring to you have?
Jimmy
Jimmy-I just wanted to see how you placed the esc in the car. Its a very tight fit with the sensor socket under the A,B,C, wire board.
One more thing, what's in beteen the motor and esc?
Thank Ed...
soloistrc is offline   Reply With Quote
Old 11-27-2010, 07:52 AM   #558
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Thank Ed...
Ed,
The power cap is between the ESC and the Motor. I had side with the motor & battery (and the sensor plug) facing to the outside of the car and the switch harness side to the inside of the car.
I had the switch & esc signal wire bundled up to the rear and then placed the esc in to hold them in place. Make sure to plug in the sensor wire on the ESC before placing it in the car, otherwise it is not possible to plug it in with how I mounted it.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 11-29-2010, 11:18 AM   #559
Trader Rating: 16 (100%+)
Thank Ed...
Yeah, that is actually Jimmy's car...and we all place our club spec the same way like that....sensor/power/motor wire side facing outside edge of car...it fit with alittle room left.
I would suggest connect the motor and test the system first before mounting the ESC as the sensor socket will be blocked by the side edge of the TA05 tub.
Old 12-01-2010, 06:17 PM   #560
soloistrc's Avatar
Thanks for the info. I will do some testing first. See you at the races...
Ed...
Old 12-01-2010, 06:29 PM   #561
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Ed...
Ed...if you are going to make it out to the Series Race on saturday swing by and I will show you how I had mine mounted in my TA05.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-04-2010, 03:39 PM   #562
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
So I bought one of these instead of getting my Tekin fixed.
Installed it with an LRP x12 17.5. Reversed the throttle on my DX3R..set EPA to 100%. Calibrated the ESC; neutral - button - one beep, full throttle - button - two beeps, brake - button - three beeps. I then reset the ESC and I get a solid yellow with a flashing red LED and I get no throttle response whatsoever. I've tried this with two other motors...Trinity D3 17.5 and SP V3 17.5. Did I buy a dud???
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-04-2010, 03:46 PM   #563
cannon's Avatar
Trader Rating: 35 (100%+)
WElcome to the world of the SP Cirtix ... biggest piece of rubbish I have seen so far.
Mine went up in smoke without having a run. Will be interesting to see at TITC with the large number of entries what happens. Hope they have plenty of spare ESC's
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 12-04-2010, 07:09 PM   #564
I missed a leg of our regional series because of this. I guess I'll send it in to see how good their customer service is.
Old 12-04-2010, 07:28 PM   #565
Trader Rating: 14 (100%+)
Try NOT reversing the throttle channel. That is what I had to do on my MX3FG.
DuckStang is offline   Reply With Quote
Old 12-04-2010, 07:37 PM   #566
Thanks...I tried that but it didn't work. Ive searched through the thread and have tried just about everything everyone has tried.
Old 12-04-2010, 10:15 PM   #567
Try setting it up again w/out reversing your throttle channel.
Old 12-04-2010, 10:17 PM   #568
Here.
http://www.youtube.com/watch?v=LX478...eature=related
Old 12-05-2010, 09:43 AM   #569
Ok, I know from experience this esc will not work with LRP motors.
Wish I would have known before you put your's in Steve and I would have told you.
We have gotten them to work with Duo 1's and 2's as well as Orion's, Novak's, but only if they have the USVTA sticker on the box.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 12-05-2010, 09:57 AM   #570
Company Representative
Please clarify: Our SS Pro and Ballistic 25.5s for USVTA are built the same as our other wind motors.
NovakTwo is offline   Reply With Quote
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
Real Stock On Road Racing... Me_MrTyson Australian Racing 214 05-19-2010 06:06 AM
