Old 10-12-2010, 02:30 AM   #481
hey guys, just wondering if there is any way you can plug a brushed motor into this speedy?
Inky is offline   Reply With Quote
Old 10-12-2010, 09:27 AM   #482
Trader Rating: 16 (100%+)
No...sorry.
Old 10-12-2010, 09:31 AM   #483
Originally Posted by V12 View Post
Someone knows what are the differences between Cirtix version 1 and 2? I know I got a version 2 some days ago and the new software is supposed to be corrected so motors from other brands are working better with the Cirtix. I think the LED also are working different as itīs not as with the instructions or was this blinking the red LED right from the version 1?
Are there any other differences maybe also hardware changes or just software?
It is not really a version 1 or 2 or 3...it is simply the older and newer batch of ESC....the July and after release ESC will work with all brands of motor including LRP and NOVAK...
Speed Passion and Trinity motors will work Ciritx no matter what stage of that ESC is...the newer batch ESC does NOT make the ESC more powerful or better then the older batch ESC. The performance is exactly the same.
Old 10-12-2010, 09:34 AM   #484
Originally Posted by markw View Post
I had my first ESC smoke this weekend. System is in a cyclone TC geared 55/88 with 18T pullies for 3.46 FDR. Motor temps have been in the 130-140 range after a 5 minute heat. I did the first qualifier, pulled the car off cleaned it up, sauced the tires recharged battery. Second heat halfway through the warmup lap it just stopped on track, then it started cogging, then it acted ok, 2 turns later it stopped. This ESC was in the original group that was purchased in June or July by the socal-rc.com for the spec class. It had appeared to thermal at one other race, yet the motor temp wasn't hot. Over temp protection is on, 0 drag brake and 100% brakes. It let go on first hard stop at the end of a sweeper.
Unless you are sure your ESC is really smoked....try the following.
Make sure the FAN is on and running...turn off the thermal protection. Double check the sensor wire....recalibrate the radio again. And give that a try.
Old 10-12-2010, 11:36 AM   #485
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Solara - how can you tell if you have a pre-July version of the controller?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-12-2010, 12:11 PM   #486
I did all that at the track, fan was running when it happened. It went on the warm up lap, one pass down the straight through the sweeper then hard on the brakes. The car wouldn't move, guy behind me bumped me and it took off, then next stop, same thing. I could make the motor run by rotating the shaft. Checked everything, it was barely warm.
When I got home I popped the case off and found this:
The middle pair of mosfets are bad, one let the smoke out and the other has a shorted gate.
markw is offline   Reply With Quote
Old 10-12-2010, 03:42 PM   #487
Kregger's Avatar
Please have your customer contact Speed Passion USA for service..thanks.
Do you have a link?
Nevermind, I was thinking I had to go through Shumacher for some reason.
Kregger is offline   Reply With Quote
Old 10-12-2010, 06:03 PM   #488
hanzo3's Avatar
Trader Rating: 55 (100%+)
I bought this used. How do u setup this esc?
hanzo3 is offline   Reply With Quote
Old 10-12-2010, 06:10 PM   #489
http://www.speedpassion.net/en/produ...?p=12280&c=ESC
The manual is available in the download tab.
Old 10-12-2010, 06:43 PM   #490
Thanks for the info, I reset my esc three times trying to stop the red led from blinking. Now I hope it works with my 25.5
Originally Posted by ghoppa View Post
on my instruction manual, the revised insert states that the red light will be "BLINKING" which notes to the user (or Tech Inspector) that the ECS indeed is set on "no timing" and the yellow light will be "solid" unless you are applying throttle and then it will be "off"; also when applying brake the yellow light will be"solid"
at least this is how it is on my Cirtix..
hope that helps you.
outlandr91 is offline   Reply With Quote
Old 10-13-2010, 09:05 AM   #491
Please do follow the below link, read thru the RMA process and send the unit back to our office...thanks
http://www.speedpassion.net/us/contact.asp
Old 10-13-2010, 10:02 AM   #492
TAMAK's Avatar
Trader Rating: 28 (100%+)
Yeah,
Taking that case off like that would void our companies warranty, and you would have to buy a new esc at a discounted rate.
I would advise everyone to NOT disassemble the esc if it smells smoked. Cause most of us know it will be a blown FET. Just send it back.
I am not sure how friendly Speed Passion is but it seems like they will replace it, even if you took the case off. Nice pic though, I see some solder splash and poor solder joints on the resistors on that board.
TAMAK is offline   Reply With Quote
Old 10-13-2010, 11:02 AM   #493
Originally Posted by TAMAK View Post
Yeah,
There was some solder splash on the board that's not there in that picture. The esc is about 4 months old so it's out of warranty. I wasn't worried about sending it back to SP, as I've got the capability to replace the mosfets. This won't be the first esc or receiver that I've repaired nor will it be the last. It is the first ESC I've had die on me though and I've been in the hobby forever. Yes, I'd agree with you, don't take it apart if you plan on sending it back.
Old 10-13-2010, 12:14 PM   #494
Yeah,
We don't recommand doing that (thank you for bringing that up) but we also do practice "being reasonable"....if it is under the warranty period, we will get that take care of. However, if it is 4 months old...then I am sorry.
Old 10-13-2010, 02:47 PM   #495
V12
V12's Avatar
OK thanks. Good to hear that.
V12 is offline   Reply With Quote
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
Real Stock On Road Racing... Me_MrTyson Australian Racing 214 05-19-2010 06:06 AM
