Old 10-01-2010, 10:40 AM   #466
Trader Rating: 16 (100%+)
Originally Posted by izzyracer View Post
Solara,
Any way you guys can put up a software update so we can use the LCD program box to make brake parameter changes on the Cirtix?
Brake parameter can be change with the optional LED programmer box...
The Speed Passion GT series LCD reads a totally different software designed for the GT series speed control. I don't think there is a plan for them to change that.
Cirtix Series ESC is a totally different line of ESC compare to the GT series from Speed Passion. They tried not to mix and match each other for the future software conflict.
Old 10-04-2010, 08:08 PM   #467
RaceAce701's Avatar
Trader Rating: 86 (99%+)
does anyone in the us have one of these speedoes in stock
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 10-04-2010, 08:15 PM   #468
Iam looking for a combo?
impdog is offline   Reply With Quote
Old 10-05-2010, 12:45 PM   #469
seth556's Avatar
Trader Rating: 42 (100%+)
Call Superior Hobbies, they had quite a few in stock this weekend. http://www.superiorhobbies.com/
seth556 is offline   Reply With Quote
Old 10-05-2010, 02:42 PM   #470
Company Representative
One of our motor customers is having problems running this Cirtix with our SS Pro 25.5 motor:
I have the Speed Passion club spec ESC http://www.speedpassion.net/us/produ...?p=12280&c=ESC
and the regular Novak 25.5 (not the ballistic)
I can't get them to work together. I can't reset the ESC. Tried hooking it up without the sensor wire and it let me set up the ESC, but it didn't run correctly (no brake, top end).
Hooked up the SP 17.5 motor I got with the package and it works fine.
Anyone heard of this problem? Possible solutions?
Any suggestions?
NovakTwo is offline   Reply With Quote
Old 10-05-2010, 05:36 PM   #471
Default Blinking Lights
Just received a pair of CIRTIX Stock Club Race ESC's. One had issues and I am sure Speed Passion will take care of it. The other is installed. I followed the directions per the instructions for calibrating the ESC and transmitter. The car works awesome but the red light and yellow light are lit. The instructions say no lights should be lit? Any thoughts? I tried reversing throttle but then it doesn't work at all. I am using a Traxxas 2.4 controller.
AE SC-10
HPI Blitz ESE (17.5 ROAR)
HPI Blitz RTR
HPI E-Firestorm
Traxxas Stampede
Chip73 is offline   Reply With Quote
Old 10-05-2010, 11:43 PM   #472
ghoppa's Avatar
Trader Rating: 54 (98%+)
on my instruction manual, the revised insert states that the red light will be "BLINKING" which notes to the user (or Tech Inspector) that the ECS indeed is set on "no timing" and the yellow light will be "solid" unless you are applying throttle and then it will be "off"; also when applying brake the yellow light will be"solid"
at least this is how it is on my Cirtix..
hope that helps you.
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 10-06-2010, 12:43 AM   #473
Technique550's Avatar
Cool
Any suggestions?
I had the same problem with a 17.5 SS it would not work together with the cirtix esc not sure why? ???
XRAY☼ Tekin☼ Spektrum☼ PRS☼ Ko Propo☼
Technique550 is offline   Reply With Quote
Old 10-06-2010, 05:26 AM   #474
Helps allot. I didn't get an insert. That is what mine is doing.
AE SC-10
HPI Blitz RTR
HPI E-Firestorm
Traxxas Stampede
Old 10-06-2010, 10:16 AM   #475
Any suggestions?
Please have your customer contact Speed Passion USA for service..thanks.
Old 10-06-2010, 10:43 AM   #476
Here is the thread with his information:
http://www.rctech.net/forum/radio-el...ak-25-5-a.html
Old 10-06-2010, 02:25 PM   #477
Hello there,
I just got the Cirtix Stock Club Race ESC and Ultra Sportsman V2 10.5R motor combo. I got it for a special project and my dealer and I didn't realize that the ESC doesn't support reverse and the project needs the motor to run in reverse only.
Well, I can just swap around 2 motor wires, and the motor will run backwards but then I need to disconnect the sensor wires and by doing that, I loose the low RPM torque.
So is there some way to swap around some of the sensor wires to allow the motor to run backwards in sensored mode?
I know a lot about electronics in general but brushless motors and controllers (the ESC) is new to me.
I guess if the motor timing is 0, then it should be possible to swap the correct sensor wires according to the swapped power wires and make it work.
Regards,
Futterama
Futterama is offline   Reply With Quote
Old 10-06-2010, 05:21 PM   #478
The lights are supposed to be on.Like mine I'm sure yours came with a single piece of paper with the instructions for the cirtix stock spec,thats the one you should go by and says the the red led will blink while in use and the yellow will stay on when in neutral and will go out when throttled.The other instructions are for their other esc's.I went thru this also.
airwoods is offline   Reply With Quote
Old 10-07-2010, 11:28 AM   #479
V12
V12's Avatar
Someone knows what are the differences between Cirtix version 1 and 2? I know I got a version 2 some days ago and the new software is supposed to be corrected so motors from other brands are working better with the Cirtix. I think the LED also are working different as itīs not as with the instructions or was this blinking the red LED right from the version 1?
Are there any other differences maybe also hardware changes or just software?
V12 is offline   Reply With Quote
Old 10-11-2010, 05:58 PM   #480
I had my first ESC smoke this weekend. System is in a cyclone TC geared 55/88 with 18T pullies for 3.46 FDR. Motor temps have been in the 130-140 range after a 5 minute heat. I did the first qualifier, pulled the car off cleaned it up, sauced the tires recharged battery. Second heat halfway through the warmup lap it just stopped on track, then it started cogging, then it acted ok, 2 turns later it stopped. This ESC was in the original group that was purchased in June or July by the socal-rc.com for the spec class. It had appeared to thermal at one other race, yet the motor temp wasn't hot. Over temp protection is on, 0 drag brake and 100% brakes. It let go on first hard stop at the end of a sweeper.
markw is offline   Reply With Quote
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
Real Stock On Road Racing... Me_MrTyson Australian Racing 214 05-19-2010 06:06 AM
