Old 09-17-2010, 11:15 AM   #421
Trader Rating: 16 (100%+)
Originally Posted by jackdani View Post
u r right...
i m worryng only because this is my first car and my first lipo and my first brushless!!!
so in the case my lipo is not well charged or i miss something i dont want theme to be ruined.
this is what i was asking....u r a big help!!
so the car will stop anyway befor 10 minutes because the esc will cut around 3.5 right?
may i ask u another question because u seems to know well the club race combo.
i adjusted the throttle range the first time i switch on the esc ad told in the manual, BUT i forgot to put throttle on REV before doing it. anyway it worked and the motor seems to rum properly BUT the lights are strange:
red light flashing even in neutral and yellow light always on....is this a problem?
thanks
Yes...you are doing fine as long as your car is going FORWARD when you apply the throttle in forward position. Don't worry about the lights too much.
The throttle REV is more for the Futaba Radio.....
Old 09-17-2010, 11:33 AM   #422
js058515's Avatar
"Low voltage cut-off protection: If the lithium battery pack’s voltage is lower than the threshold for 2 seconds, the ESC will cut the output power. Please note that the ESC cannot be restarted if the voltage of each lithium cell is lower than 3.5V. You can disable cutoff voltage protection function for competition racing.
For NiMh/NiCd battery packs, if the voltage of the whole NiMh/NiCd battery pack is higher than 12V, it will be considered as a 4 cell lithium battery pack; If it is higher than 9.0V but lower than 12V, it will be considered as a 3 cell lithium battery pack; If it is lower than 9.0V, it will be considered as a 2 cell lithium battery pack. For example, a NiMh battery pack is 8.0V, and the threshold is set to 2.6V/Cell, so it will be considered as a 2 cell lithium battery pack, and the low-voltage cut-off threshold for this NiMh battery pack is 2.6*2=5.2V."
Source: Cirtix series Brushless Motor Speed Controller manual “V1.1-5222010a”
js058515 is offline   Reply With Quote
Old 09-17-2010, 11:41 AM   #423
jackdani's Avatar
Originally Posted by js058515 View Post
"Low voltage cut-off protection: If the lithium battery packs voltage is lower than the threshold for 2 seconds, the ESC will cut the output power. Please note that the ESC cannot be restarted if the voltage of each lithium cell is lower than 3.5V. You can disable cutoff voltage protection function for competition racing.
Source: Cirtix series Brushless Motor Speed Controller manual V1.1-5222010a
so cut off will work even if i dont/cant set it...as the manual seems to say???
jackdani is offline   Reply With Quote
Old 09-17-2010, 01:30 PM   #424
IndyRC_Racer's Avatar
Can't seem to get my Cirtix Stock Club ESC to work with any sensored motor. When I turn on the speed control with the sensored wire attached, it has a constant beep, beep, beep, etc... If I remove the sensor wire, the speed control seems to work normally as well as the motor attached to it.
Was planning on using this speed control with a 25.5 in VTA.
I have tried 2 different brushless motors - an old Novak 4300/10.5 and a Ballistic 25.5 motor with the same results. I have double checked that the ABC wires are attached in the correct order on the speed control. I have also tried 2 different receivers with the same result.
I have tried 2 different Futaba transmitters and have confirmed that the throttle channel was "reversed".
I did shorten the speed control to receiver wire, but I have also double checked that those connections are good.
Anything obvious that I'm overlooking??
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 09-17-2010, 03:32 PM   #425
See you can borrow a SPEED PASSION or TRINITY base motor and give that a try...just try to make sure the ESC has problem or not. Give that a try first.
Old 09-17-2010, 09:49 PM   #426
qcrc's Avatar
Did the wires get reattched in the right order? Might be the causeif they are wrong.
https://www.facebook.com/ISLANDSPEEWAY/
qcrc is offline   Reply With Quote
Old 09-18-2010, 11:11 AM   #427
CLK@racing's Avatar
Hi,
Anyone can advise on the gear ratio range for this combo on 13.5 and 17.5?
CLK@racing is offline   Reply With Quote
Old 09-18-2010, 11:32 AM   #428
Originally Posted by [email protected] View Post
Hi,
For 17.5 anywhere from 3.3-4.0 depending on track and size.I just ran mine last night at a local hobbytown,raced rcgt with it in my cyclone s geared 3.72.It had good punch infield and good top end for our short staightaway.Not sure though where the motor should be temped but on the side it read 180'ish and the back 130'ish after a 5 min heat race.The ambient temps were around 100 and the track lots more than that.This esc and motor ran great and gave me no problems so far.
airwoods is offline   Reply With Quote
Old 09-18-2010, 12:15 PM   #429
trx450racer174's Avatar
I have my 2 Cyclones geared at 3.5 and run them on small to large tracks asphault tracks.
Temp on the motor is usually 125ish.
Last time out it was 100+ outside and the motors got warm 160+ so i added heatsinks and fans to be extra cautious.
E.K.D. RC Paint Work
Team Serpent USA, Desoto Racing , Team DE Racing, Team Hitec, Team Trakpower, Futaba, Team AKA, TrackstarRC.
trx450racer174 is offline   Reply With Quote
Old 09-20-2010, 03:58 PM   #430
mr240's Avatar
Trader Rating: 61 (100%+)
Anybody got an stock spec ESC they want to sell.
mr240 is offline   Reply With Quote
Old 09-20-2010, 05:28 PM   #431
js058515's Avatar
I swore I saw one in the for sale thread a couple days ago. They wanted $50 shipped for just the ESC.
Old 09-22-2010, 11:57 AM   #432
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
after 1 year and half out of racing, I came back last week.
got the second best time, finished 3rd.
track is around 70 feet x 70 feet
losi type r
rubber tire
17.5 combo
4.8 fdr and i was getting a temp of 100
4.6 fdr and I was getting around 115
next time I will try 4 - 4.4 fdr
what will be the max temp for the 17.5 motor?
thanks
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 09-22-2010, 01:50 PM   #433
js058515's Avatar
I have had mine up to 170, but I didn't like it there at all. My local track has a Citrix 17.5 series and that track owner seems to like the motor temp around 150.
When I ran my combo in my Type R, I was getting only 105 running 3.9 FDR. Track is indoor carpet and not sure of exact measurements.
losi type r
rubber tire
17.5 combo
thanks
Old 09-22-2010, 08:19 PM   #434
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
hey guys - just got one of the Cirtix speedos and i got a question..
was looking thru the instructions and didn't see how to program the speedo WITHOUT the box - is this possible?
Its the club spec so i know i can only do so much adjusting, but like to remove some drag brake and adjust a couple of the other things I can
thanks for any help - tomorrow at work, i'll go thru the whole thread
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-22-2010, 09:01 PM   #435
js058515's Avatar
You will need access to a programming box to make any changes. If you got it from a LHS or a track/Hobby shop I am sure they will let you use theirs. My track let me, of course that's where I bought it from and they run a Citrix 17.5 series.
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
Real Stock On Road Racing... Me_MrTyson Australian Racing 214 05-19-2010 06:06 AM
