Old 09-05-2010, 05:29 PM   #391
js058515's Avatar
Originally Posted by Damnit Man View Post
Anyone know if they sell just the motor by it's self? If so who sales them?
http://www.tqrcracing.com/shop/produ...yword=&pg_no=1
I just picked up the last 17.5 combo today from TQ. These things don't stay in stock for long at $87 OTD.
Speedtech is showing the combo in stock, you can alway sell the esc separately.
https://www.speedtechrc.com/store/eb...id=918&id=9620
js058515 is offline   Reply With Quote
Old 09-08-2010, 08:01 AM   #392
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
Hey, I got my cirtix stock combo (esc + 17.5) last nigh.
I did the installation as per the manual.
It work
HOWEVER, on neutral position the manual said that the 'led' should be off and that on forward, the red light should be on. I have the inverse situation. is that normal?
Also I will be using a losi type R with 2 cell lipo. what will be a good rollout (3.5?).
Inside track, carpet.
thanks
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 09-10-2010, 11:50 AM   #393
stitchy's Avatar
We (SpeedtechRC) have two motors that we can sell separately for $45 each.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 09-10-2010, 09:31 PM   #394
Trader Rating: 26 (100%+)
svines1972 is offline   Reply With Quote
Old 09-14-2010, 05:42 AM   #395
Farmer_John's Avatar
Any more ideas or solutions on running this esc on 1s?
Join the Pancar nation
https://www.facebook.com/oneeigth2wdpancar/
Farmer_John is offline   Reply With Quote
Old 09-14-2010, 09:57 AM   #396
js058515's Avatar
I think there is only 2 ways at this point until SP creates a way within the ESC. My local track runs these in 12th Pan with some using 150-280mah rx batts or using TQ Cells booster. The track actually has a Citrix Spec 17.5 class for 12th scale so they must be having very few issues with these 2 options.
www.tqrcracing.com is my local track
www.tqcells.com is where u get the TQ booster
They are not related, just coincidence. Amainhobbies sells their Protek brand rx pack for around $10 and the local track sells a Dynamite brand pack for $20.
Old 09-14-2010, 11:30 AM   #397
Ok, that's good to know as there seems to be contradicting information as whether or not you can use a receiver pack with this setup.
If there is a way to explain how to wire it successfully, that would be even better.
Old 09-14-2010, 12:15 PM   #398
The middle wire (red) is +4.8v to 6v, ALL the connectors in your receiver are tied to that, this is why you can plug a battery into any connector on the receiver or plug stuff in backwards without smoking anything. To run a separate battery or BEC, you need to remove the middle wire from the connector on the ESC. I've found the easiest way to do this is to get a short servo extension and just cut the middle wire.
markw is offline   Reply With Quote
Old 09-14-2010, 01:43 PM   #399
stitchy's Avatar
oops forgot the link
Old 09-16-2010, 03:26 PM   #400
jackdani's Avatar
hi everyone,
i need some help.
i got my combo 10.5T last night and i m wondering how to install it.
i m confused about the settings...because the manual is not so clear.
in the club race version we dont have to worry about cut off for lipo, it is right?
it is unsettable?? am i right?
should i switch it on and set the throttle range and thats it?
and later if i want i can set the other 3 option which actually are abs, drag brake, and temperature?
is this correct?
if someone would help me i will be very pleased because i dont want to bury a lipo!!
tnx
jackdani is offline   Reply With Quote
Old 09-16-2010, 06:56 PM   #401
Originally Posted by jackdani View Post
hi everyone,
i need some help.
is this correct?
tnx
just bought one of these also in 17.5 to race in rcgt.It is non adj thru the transmitter and esc you have to buy the programmer,I bought it last night at speed passion site for $9,they are on sale $14 total with shipping.
airwoods is offline   Reply With Quote
Old 09-16-2010, 07:07 PM   #402
For guys running tc has anybody with the programmer gone thru and made any adj with good results or are the factory default settings working for most.Also it says you must recalibrate after any adj made to your transmitter settings.Didnt think it was neccessary but when I turned down my epa for brakes from 160% to 80% the wheels started to move forward slightly so had to adj throttle trim,after this I set my epa brakes from 160% to 100% and recalibrated the esc and now I'm good and the wheels dont move from 100% to 160% all the way down to below 50% before the wheels start to move again and my throttle trim is now centered.
Old 09-16-2010, 07:27 PM   #403
js058515's Avatar
I think the programmer is necessary, fortunately is low cost. I changed the drag brake and brake settings to suit how I like it. Good system so far, just plug it in and run. Of course what your temps.
Old 09-16-2010, 08:11 PM   #404
First race with it tommorrow night,small to medium size track at a local hobbytown,have it geared in a cyclone s at 3.7 right now and have a 4.0 incase it gets hot.So I assume now that you adj your brake settings thru the esc and programmer do you still make small brake adj with epa thru the transmitter.
Old 09-16-2010, 08:39 PM   #405
js058515's Avatar
EPA adjustments is definitely needed to fine tune brakes as the esc is set for 10% increments up to 100%.
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
Real Stock On Road Racing... Me_MrTyson Australian Racing 214 05-19-2010 06:06 AM
