Speed Passion Cirtix Stock CLUB ESC >
Old 06-07-2010, 06:54 PM
  #136
tiko's Avatar
Trader Rating: 35 (100%+)
Originally Posted by SRBMOJO View Post
same symptoms as you, excet when I turn it off, then on it works fine. The lights are on and flashing at startup, but everything works on the track. I have a Futaba 3PM.
Did you change the wires that came with the ESC or youíre using whatever came with it. Also what car did you put it in TC or 12 scale.
tiko is offline
Old 06-07-2010, 07:11 PM
  #137
SRBMOJO's Avatar
Trader Rating: 67 (100%+)
wires are stock, I cut the funky motor plug and soldered directly to motor, used 4mm bullet plugs on battery side, receiver and fan wires are stock, used an LRP sensor wire, in a TC.
SRBMOJO is offline
Old 06-07-2010, 07:24 PM
  #138
tiko's Avatar
Exactly what I did except I unplugged the fan because Iím using it in a 12 scale. I hope I can get a hold of someone tomorrow at Speed Passions tech department to figure out what to do with this thing.
tiko is offline
Old 06-07-2010, 07:59 PM
  #139
Ericjooopuntnl's Avatar
Originally Posted by andrew188 View Post
Is this speedo as fast as mod motor ESCs without boost, such as LRP Sphere TC or SXX TC?
Last week we tested the Cirtix together with Tekin RS Pro, LRP SXX and the LRP SPX with a SpeedPassion 13.5 v3 with max timing on the motor. All ESCs on program 0-timing and boost. The result was very equal, laptimes differed around 0,05s max.
We did drive with 4-6 cars at the same time and all the guys had real fun, big smiles afterwards. We also checked topspeeds on a 35m straight. 45 km/h entering the straight and between 57 and 60 km/h at the end. When we switched motors the topspeed difference was the same, just a bearingproblem. One motor had the original blue bearingoil and the other one was already prepped without the blue stuff. This made the 3 km/h topspeed difference!!
So imo Stock is back!!!
greetz,
Eric
Ericjooopuntnl is offline
Old 06-07-2010, 09:47 PM
  #140
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Technique550 View Post
anyone have any trouble with getting into programming and or getting your programming to finish ??? I spent two hours last night battling my stock spec esc
The programing wouldn't finish on mine either, but if you turn it off, then back on it seems to work. The red and yellow lights flash, but seems to work fine, haven't driven on the track with it yet though.
you say programing, but the only thing you can set is the brakes and drag brake on this esc, if you are trying to use the program card that came with a different esc, i.e the gt 2.0 or pro stock 2.1, it will not work, there is a new program card for this esc. it is sold seperately, I don't have the part number right off hand.
skypilot is offline
Old 06-07-2010, 11:07 PM
  #141
SRBMOJO's Avatar
No, you have to set the neutral, wide open throttle and full brake positions on your radio to the esc.
SRBMOJO is offline
Old 06-07-2010, 11:33 PM
  #142
I used mine with my DX3s no problems
reverse throttle
Press the button
turn it on
press button for neutral
press button for full throttle
press button for full brake
turn off , turn on sorted
this was the only thing i didn't have problems with over the ETS weekend
sidecarphil1 is offline
Old 06-07-2010, 11:35 PM
  #143
Super Moderator
charlie_b's Avatar
To set up you esc, please watch the video. No, it isn't me in that video.
ESC SET UP
charlie_b is offline
Old 06-07-2010, 11:51 PM
  #144
tiko's Avatar
reverse throttle
Press the button
turn it on
ESC SET UP
Guys thatís what I have been trying to do all day itís still not working. Also no beeping sound from the ESC.
tiko is offline
Old 06-08-2010, 12:56 AM
  #145
Super Moderator
charlie_b's Avatar
Tiko, are u in Socal? Maybe i can meet up with u to check it out. Im out here in Orange County. Maybe we can meet at Ultimate Hobbies or something. I can take a look at it and see what the problem is.
Old 06-08-2010, 01:10 AM
  #146
tiko's Avatar
I am we actually met before at Tamiya and Roadrunners. I got the combo from Sean at TQ last Saturday for the upcoming carpet series. I wanted to go to TQ tomorrow for practice but I canít get the ESC working.
tiko is offline
Old 06-08-2010, 02:32 AM
  #147
Robert_K's Avatar
greetz,
Eric
Eric,
That's really good to read! Was this at Apeldoorn or at Mach?
I think all club's should switch to a zero timing "stock" class, Also the nationals should switch next year.
We'll keep in touch,
Robert
Robert_K is offline
Old 06-08-2010, 12:00 PM
  #148
Originally Posted by Robert_K View Post
Eric,
Robert
We got one in Groningen , 10.5 zero timing speedos , works really well , close racing and some quick lap times
Old 06-08-2010, 01:17 PM
  #149
Jochim_18's Avatar
Per ROAR Rules if you are running SPORTSMAN in a national event you will have to use ESC with zero timing/Boost.
Jochim_18 is offline
Old 06-08-2010, 02:14 PM
  #150
skypilot's Avatar
check and make sure you have it plugged in the rcvr the correct way??
skypilot is offline
