Mission Impossible ? >
Old 04-29-2004, 10:34 AM
Unhappy Mission Impossible ?
Hi guys.
I have a schumacher mission carbon. There is one problem in it now The front one-way diff does allways get loose. I need some adwise from som genius because I just canīt fix this and I was going to race this weekend but if I canīt fix this I wonīt race
Bjarni is offline
Old 04-29-2004, 12:17 PM
rc_square24's Avatar
are all the roller pins in the oneway bearing in place when you look inside with the outdrive taken off?
rc_square24 is offline
Old 04-29-2004, 12:35 PM
Get a ball diff....instant fix to ALL problems...parts AND lap times One ways suck anyway If you want the acceleration just lock it into a spool or get a better motor
The Black Kat is offline
Old 04-29-2004, 01:38 PM
fatdoggy's Avatar
The Black Kat - It all depends on driving style. One-ways are VERY effective if you know how to drive with them.
fatdoggy is offline
Old 04-29-2004, 04:58 PM
Doggy- you still running on the rug?? Planning on any outdoor excursions this summer??? Me I'm racing nitro dirtoval mostly this outdoor season......... but I may make the trip down to Fredrock once or twice......
IMPACTPLAYR is offline
Old 04-29-2004, 05:00 PM
BTW: Bjarni, have you checked all of your front and rear end bearings lately??? they can definately make a one-way feel bad.....
Old 04-29-2004, 05:07 PM
Fatdoggay....I can drive the car but its just the unpredicability really bites me...I have to be able to predict what my car will do before I tell it to do it
BTW: Just a belt-drive car hint....cut off every other tooth on the belt. Frees the drivetrain up a bunch
Old 04-29-2004, 05:14 PM
fatdoggy's Avatar
Impact - Yer I'm still running on rug for now but it's pretty much dead, there's still 5 or so that run though. Has frederick sorted out the computer problems? I see little point going up if nobody's running ele and they have computer problems all day long. So nitro dirt oval and I was under the impression you HATED nitro. If you get an itch to run ele outdoor at frederick shoot me a pm and I'll see if I can make it up.
Cheers mate.
fatdoggy is offline
Old 04-29-2004, 05:47 PM
I really like the one way in my xray. On the parking lot races my car sucked with dual diffs. When I put the one way in... it still kinda sucked but it was atleast drivable. I think its all personal preference. You also might need to change some things on your set up if you put a one way in.
racerdx6 is offline
Old 04-29-2004, 05:56 PM
imo on carpet the one-way is the only way to go with rubber tires and faster lap times 99% of the time
R/C Anonymous is offline
Old 04-29-2004, 06:04 PM
Carpet & Rubber tires is what I do 99% of the time and a one-way doesn't work 100% of the time
Old 04-29-2004, 06:34 PM
burbs's Avatar
i also agree i run rubber tires on carpet to... the one way does in my opinion make lap times faster if u like to drive that way... but i found it to be very inconsitent. when i run the ball diff my times are very close from run to run.. when i ran the one way i would have a fast run then a slow run.. id rather be fast and consistent then fast and inconsistent...plus a diff is cheaper to rebuild...
burbs is offline
Old 04-29-2004, 08:11 PM
Thats wierd because I put a one way in right before my first qualifier the first day I ran one and the car was better all around. I didnt have any problem driving it. The only problem is breaking with one. Which you cant do.
racerdx6 is offline
Old 04-29-2004, 08:14 PM
fatdoggy's Avatar
racerdx6 - Maybe you should work on setup.
I use a front one-way in stock, foam on carpet(not possible with mod) and it absolutly screams. I know foam is very different then rubber, alot more grip. Just completely dial out all brakes and find a setup that works well and go from there. With stock racing brakes arn't needed anyway, just use the natural drag-brake from the high timing.
P.s. - If you can't be consistant or don't have a setup that lets you be consistant then your screwed to begin with.
fatdoggy is offline
Old 04-29-2004, 08:41 PM
Wency_TA03R-PRO's Avatar
Exclamation
Bjarni
Did you check on the part no of that one way?! or hop-ups part no perhaps?. Co'z as I change my bevel gear set to a one-way gear set it just simply a plug-n-play sequence. I did'nt encounter getting it loose.. check your set-up properly. I also agree with what fat doggy stated that its very effective if you know how to properly handle it.
racer dx6 The black kat
I also agree with wath you have mention. One-way and ball diff are really great especially when your running on a tight/technical race track. You can really feel the effect and its response.
IMPACTPLAYR
yup! l agree with you bro!. try to double check the other bearings..
Hpoe you can fix it before weekend.
Wency_TA03R-PRO is offline
Copyright Đ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
