belts: cutting every OTHER tooth??? >
Old 04-29-2004, 07:23 PM
  #16
FIRE RIDER's Avatar
I was wondering why when i bought my losi used that there were teeth missing on the belt. i never thought to ask, i just thought that it was made that way.
FIRE RIDER is offline
Old 04-30-2004, 12:13 PM
  #17
rtypec's Avatar
I heard if you cut every other tooth on the belt, pulleys, spur and pinion gear, you'll be super dialed
rtypec is offline
Old 04-30-2004, 01:02 PM
  #18
Post
I have heard that each tooth cut off of the pulley = 0.1 secs off of your time.
I am going to try a two tooth layshft pulley and four on the diffs.
I should make the A this weekend.
IncogneatO is offline
Old 04-30-2004, 02:33 PM
  #19
Wink
I've seen my buddy's belt break in stock from shaving every other tooth off the pulley. Just run mod and you don't have to do some of these crazy little things to be fast.
Masterfaster is offline
Old 04-30-2004, 02:45 PM
  #20
BuddyB's Avatar
At the carpet nats i seen Todd Hodge break a belt, but he said that it was the black belt that he put in over a year ago. And i did do that with yellow belt, but with how hard it was for me to get the black one i didnt chance it.
-Buddy
BuddyB is offline
Old 05-01-2004, 12:42 PM
  #21
Cole Trickle's Avatar
Try cut off the last four on the diff - then you should be 0,4 sec. faster
Cole Trickle is offline
Old 05-02-2004, 07:48 PM
  #22
FlyinGT's Avatar
Default Wears Out .!!
I've just got back from a big meet .....!!
since i'd cut the tooth off my belt (an old belt)
it quickly started to get chewed up an ripping ....
after bout 5 races of 5 minutes in stock ....!!
so if u are trying this on an old belt be careful ...... there will be a chance it will snap or break......... during a race
it'll last longer on a new belt but haven't tried this yet ..!!
i still do recommend it ........ car felt better with the cut belt .!!
(but that could b just me )
FlyinGT is offline
Old 05-03-2004, 12:35 AM
  #23
Tek Nickal's Avatar
Cut them all off, you'll be like 10 min. ahead.
Tek Nickal is offline
Old 05-03-2004, 01:12 AM
  #24
xray racer's Avatar
Trader Rating: 22 (100%+)
hey everyone, thanx for your responses ,..... and please keep em coming with new findings and comments.
another question though.... what will give me a greater benefit.... cutting every second tooth off the belts, or cutting every second tooth off the diff pulleys? or even leaving only say 4 teeth on the pulleys
let me know as im about to order some things in and was wondering whether to get a belt or diff pulleys
thanx
robbie
xray racer is offline
Old 05-03-2004, 01:21 AM
  #25
i cut every other tooth off my belt and i did not see that big of a deffents and when i run mod it skips
meat head is offline
Old 05-04-2004, 06:49 PM
  #26
FIRE RIDER's Avatar
tighten the belt up if it skips. i had my brushless in and it skipped so i tightened it up and it hasnt skipped since. i have a losi so i dont know about tightining up belts on outher cars.
Old 05-04-2004, 06:57 PM
  #27
Tek Nickal's Avatar
I find that running a belt that goes to the front wheels loose, really helps the car feel smoother.
Old 05-04-2004, 07:38 PM
  #28
=MisFitz= NuKe's Avatar
well, tightening the belt, makes it less free, more drag, which is what you people are trying to be rid of with cutting teeth...DRAG, so if you have to tighten the belt to keep it from skipping, you might as well go play with some Tonka trucks
=MisFitz= NuKe is offline
Old 05-04-2004, 08:13 PM
  #29
Neil Rabara's Avatar
I don't recommend cutting the Xray belts at all. Modifying the front pulley is really all you need to do. It does decrease drag and frees up the drive train, and an added benefit is a quieter car.
Neil Rabara is offline
Old 05-05-2004, 01:25 AM
  #30
team_tamiya's Avatar
How far into the tooth should i cut. Has anyone done it with a TA04, found any diff.
team_tamiya is offline
