Old 05-02-2010, 04:10 PM   #1
drbelleville's Avatar
Default TRF 415 & 416 parts on the Older TRF 414m
Hey guys, trying to refurb a 414M that is in fairly good shape, although it needs a few parts, and I was wondering how much if any of the newer chassis sipension parts, and maybe the Spool / Diffs would work with the 414.
Thanks.
R/C'ing since 1982, Pro-10 racing in Germany and Italy in the early 90's, Keil DTM Cup.
The Pro-10 Pusher.
drbelleville is offline   Reply With Quote
Old 05-02-2010, 07:28 PM   #2
Trader Rating: 112 (100%+)
Thanks.
I have a 414MII that I installed 416 Front and Rear Shock Towers. I also installed the reversible suspension on it too. The only mod that I had to do was re-drill the lower mount holes on the shocks tower to line up with the bulkhead holes. Once re-drilled I installed the shock towers with the countersink holes facing the bulkhead and used a button head bolt.
I hope this helps you. I tried the bigger pulleys but did not work.
Dave
dragracer72nova is offline   Reply With Quote
Old 05-02-2010, 07:39 PM   #3
Did you have to switch to different cvd's? are you running the 44 or 46 Cvd Shafts? Thanks
The Pro-10 Pusher.
Old 05-02-2010, 07:45 PM   #4
team jeremiah's Avatar
I put the rear pro module set up. i also used the 415 suspension mounts, short revesable A-arm set up. you'll just need spacers and some shims.
team jeremiah is offline   Reply With Quote
Old 05-02-2010, 07:49 PM   #5
I don't remember. I bought a Tamiya Conversion for the TA04.
Dave
Old 05-02-2010, 07:54 PM   #6
You got pics of the conversion?
The Pro-10 Pusher.
