Old 04-28-2010, 11:26 AM   #1
Trader Rating: 10 (92%+)
Default front diff
coming from minimal onroad experience, I hear for outdoor, and im currently using that spool is the way to go. But so far I seem to be wearing out the outdrives and front shafts.
Would there by much disadvantage in running a diff up the front? I gather there would be less damage from crashes, and alot easier on the drive train, but what I want to ask is.........
how does a diff handle on asphalt compared to spool? More turn in? Slightly less forward traction?
a locked up front diff would act like a spool, only have abit more 'give', true?
captain stacker is offline   Reply With Quote
Old 04-28-2010, 12:00 PM   #2
MikeXray's Avatar
Trader Rating: 73 (100%+)
What car do you have? some people build slipper spools for this reason, basically a diff with sandpaper instead of diff balls, it will give under a big hit.
Typically a diff is slower out of the corner, but if your car is a little tail happy it actually calms it down.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-28-2010, 09:01 PM   #3
tamiya, I also just found out they make delrin cups, so that may help make the outdrives last abit longer.
thats interesting with the sandpaper!
Old 04-28-2010, 09:25 PM   #4
niznai's Avatar
Yep, all of that.
You could also try a front and/or center one-way if your rules allow it. This will give you the spool rip out of the corners coupled with the turn in of the diff (actually a lot more) but will completely take away any chance of using brakes in corners. Even in a straight line it will be tricky to master braking with one ways.
I think the sandpaper locked diff is the best option but you need to test and tune the tightness between stripping the screw and having the diff too loose. Perhaps different sandpaper grades too.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 04-29-2010, 03:13 AM   #5
losi has the sandpaper disks. feels like 120-150 grit. they do wear out with time. most run the front diff tighter than the rear to lock it up more. tight short courses are better with a diff. losi runs plastic in the front and metal in the rear outdrives on some cars. that's cause the front steering action puts twice the wear on bones and outdrives.
speedster1919 is offline   Reply With Quote
Front diff getting more power than the rear? pinky2252s Nitro Off-Road 18 12-07-2009 03:35 PM
FS: Schumacher Mi2 One Way Front Diff Ian_da_bomb R/C Items: For Sale/Trade 16 09-14-2005 12:28 AM
First time running One-Way Front Diff holycow Electric On-Road 18 09-08-2003 01:05 PM
take this one way and shove it! going back to the geared front diff cybertoolzz Nitro On-Road 17 04-03-2003 06:51 PM
