Old 04-23-2010, 10:36 PM   #1
monkee's Avatar
Trader Rating: 15 (100%+)
Default which type of wheels
im using a tamiya ta05 and a tl-01 which typically takes a 190m shell.
i want to buy a 200m shell.
what wheels should i get to make it look right?
monkee is offline   Reply With Quote
Old 04-23-2010, 10:40 PM   #2
monkee's Avatar
looks like their is offset options...
would i want 3mm or 6mm offset
Old 04-23-2010, 11:53 PM   #3
its mostly preference. most cars are a little under 190 so you would need the 6mm to get close enough to 200mm. that offset should be for each wheel. you can also buy thicker hexes for some cars. traxxas has some wheel hex hubs that are atleast 3mm thicker than most. getting wider wheels and tires also helps so there are lots of things you can do to make your car look better with a 200mm body and not have the wheels to deep inside.
benben10 is offline   Reply With Quote
Old 04-24-2010, 12:02 AM   #4
monkee's Avatar
**edit..
thank you
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Post pics of your 1/8th scale buggys mrfastrc51 Electric Off-Road 207 03-08-2011 06:13 PM
1/10 Sedan Quick Release wheels rcracerdude Nitro On-Road 68 09-23-2006 08:22 PM
Trinity G4 - Team Magic G4 E-Type puma1824 Nitro On-Road 3128 10-04-2005 05:17 AM
