Old 04-21-2010, 05:37 PM   #1
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
Default Mod racing with T2 009
Hey guys got some modified racing coming up and was just wondering roughly what a good roll out is to aim towards with a 5.5t Novak. I was running it yesterday for a few minutes with 26 degrees positive timing programed into the ESC (not using a sensor cable so no timing in the motor due to motor playing up when using sensor cable but works fine without it) with 24mm rollout and it got to hot to quickly for how long I ran it. I since have put the timing down to 18 degrees timing and havent changed the gearing.
Ill run it again this afternoon but if it runs cool/hot with the current setting what would you recomend to change? (timing up/down or up/down in gearing) Obviously I would like as much speed as possible with the motor still staying under 75-80 celcius after 5 mins.
Also Ill be running it in the day which is generally around 25-29 Celcius so I have to allow for that aswell.
Thanks for any advise or help
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 04-22-2010, 02:01 PM   #2
RTR canada's Avatar
well i managed to get a 118 spur on my 009 with a tiny bit of grinding to the chassie. drives great and that way you dont have to get alot more pinions
RTR canada is offline   Reply With Quote
Old 04-22-2010, 03:45 PM   #3
Wat the hell! Ive got a 86 tooth on there at the moment and if I went any bigger it would sit out the bottom of the chassis and scrape on the ground. Even with grinding dont know how you managed to do that!
Old 04-22-2010, 03:50 PM   #4
I'm pretty sure his 118 is 64 pitch and your 86 if 48p.
the_kid9 is offline   Reply With Quote
Old 04-22-2010, 04:27 PM   #5
Oh yeah true, sorry didnt think about that
Got a few theories for the car at the moment for temps and speed. Ill let you know how it all goes...
Old 04-22-2010, 09:04 PM   #6
Aim for FDR ~ 8.5 to start, so if you use a 86 spur, then try a 19 pinion to start.
hardmankam is offline   Reply With Quote
Old 04-23-2010, 12:21 AM   #7
Yeah thanks for that. I started at 8.5 FDR but have been told by a highly experienced Mod racer to go for between 7.5-7.8 for the track and weather condition we have here. And if use a 19tooth with the 86 tooth then I get 7.69, not 8.5 as mentioned above. So ill try that and see how I go. Thanks
Old 04-23-2010, 02:52 AM   #8
u must be using internal ratio of 1.7 instead of the more common 1.9. If your track is large with flowing corners, then u can gear it more aggressively.
moreover , for mod motors , u dont want to add too much timing to the motor and the esc. too much timing will cause heat but the car will not go that much faster. it is better to put less timing and play with gearing.
XRAY T2009 bola Electric On-Road 2679 07-06-2014 06:25 PM
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 09:06 AM
Xray T2 009 carpet setup with rubber tyres FLAT OUT Electric On-Road 13 09-27-2009 12:57 PM
Xray T2 009 is here FK05 lover Australian Racing 436 08-02-2009 03:41 AM
